Thanks for the info.
On page 9 of the ECi Operating Instruction Manual it says:
http://www.eci.aero/exp/FIS_operatingmanual.pdf
4.2 Starting the Engine
This procedure is recommended for both cold
and hot starts:
Make sure that the propeller is clear and that
no personnel are in the immediate vicinity.
1) Open the throttle approximately 1 inch, and
move the mixture control to the full-rich
position.
2) Turn on the airframe boost pump on high
pressure for one to five (1-5) seconds and
turn it back off.
3) Immediately start cranking the engine over
until it starts.
4) As the engine starts to accelerate in RPM,
smoothly move the throttle towards the idle
position to prevent the engine from running
into a high RPM condition
More info: The engine is equiped with the ECi Cold ram air induction, dual PMags, ECi fuel injections. The first time away from home landing at KNB (Kanab, Utah) ECi recommended cold start/hot start method was used with out the engine starting. I then tried the more typical/standard start similar to what Dave suggests. Which didn't work readily (maybe I just didn't let it turn enough). Then the fuel pum was employed which got it started. By the way the pump is started after the prop starts turning.
Stein, my FI system is an AE Mechanical FI ECi system. By the way all that electrical stuff that you sent my way while lowering the fatness of my wallet has worked wonderfully......SO THANKS.... I also want you to know I was introducted to VAF and other sites during the high point of the world primer wars......gotta love opinions and those that stay at Hoilday Inns.
Dave, I have tried your suggested ....probably best...way to start a hot FI engine. It did turn more than ten blades, but I must admit I maybe wasn't patient enough to allow all that hot fuel to flow through. I will go back and give this another try on the next flight.
Bud, Bobby is just a great guy with alot of great info. I have discussed this with him and have told him of the novel way I start a hot engine. He wasn't overly conserned.
I do hope I can get the engine to behave using Dave's (more standard) hot start method. We will see!!!!
Finally the engine is still not broken in.....
Anyother ideas out there that may help send it this way.
Frank @ 1L8 and SGU ...RV7A... Phase 1
