In the RV-6, the access plate is the same size as the doubler ring. The doubler goes on the inside of the rib with nutplae riveted through the rib and doubler. The plate screws to the outside of the rib. Don't know if it is different on the 7 though. The 6 plans specify 6 3/4" OD for the ring and the plate. 5 1/4" ID for the doubler ring.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
