Old 09-28-2009, 05:24 PM
LarryT LarryT is offline
Default 12V fan - electrical noise
Is a small 12V axial fan with a brushless motor likely to be a source of radio noise?
I am wondering because I would like to attempt a power ventilation experiment.
Larry
Old 09-28-2009, 05:42 PM
fmarino1976 fmarino1976 is offline
Default Brushless fans
are typically not electrically noisy. Where I work, we use them on some helicopters with extended instrument panels to help circulate air through the enclosure. We haven't had any problem with them interfering with the radios.
A&P, IA, Avionics Tech, and finally: Pilot! (12/28/06)
Dying to build an RV10. Not quite ready yet
Old 09-28-2009, 06:31 PM
Walt's Avatar
Walt Walt is offline
I installed a small "cyclone" avionics cooling fan this summer and no problem except for the little bit of noise it makes while running and you can hear a little whine in the audio on shut down. Worth is to keep the electrons cool
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
