09-27-2009, 09:57 PM
Odyssey Battery Posts
The Odyssey battery I bought from Van's come with two brass angles and stainless hardware to make the wire connections. I have seen other Odyssey batteries with big honking looking terminal posts. Anyone know if there is an advantage one way or the other, did you use the brass angles or just run a bolt through the ring terminals right into the threaded batter post hole? Thanks for any info.
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
09-28-2009, 06:32 AM
VAF Moderator / Line Boy
I just put a metric bolt through the battery cable end and screw it to the battery Mike - direct connection, no extra hardware.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
09-28-2009, 09:29 AM
Senior Curmudgeon
Paul
Yep, less is best
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
09-28-2009, 11:06 AM
I drilled and tapped the post for "real" hardware and bolted the ring terminals directly. Has worked fine for several years now.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
09-28-2009, 05:46 PM
Used the bolts supplied and went directly to the battery. No additional parts required!
09-29-2009, 01:29 AM
What is "real" hardware. As opposed to "unreal"? "Fake"?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
