Old 09-27-2009, 10:09 AM
prkaye prkaye is offline
Default trutrak load
Anybody know how many amps my TruTrak pictoral turn & bank instrument should draw? The unit didn't come with any documentation.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-27-2009, 10:14 AM
Auburntsts's Avatar
Phil,
Looks like the control head draws 0.3 Amps according to the manual.
http://www.trutrakflightsystems.com/...dUserGuide.pdf
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 09-27-2009, 10:16 AM
Auburntsts's Avatar
Disregard. I just saw that you had the turn and bank and not the AP.
PP ASEL-IA
WAR EAGLE!
Old 09-27-2009, 10:33 AM
breister breister is offline
Yep, the servos draw a couple of amps, but the control head load is almost nil.
Old 09-27-2009, 11:18 AM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default Belt and suspenders
I have the 2 1/4" Trutrak pictorial T&B. I had measured current consumption to be about 55 to 65 mA.
I installed a switch to select between the main electrical bus, or the alternate 9V battery supply. This allows the T&B to operate on emergency 9V power, and along with my other steam gauges, hopefully will allow me to get out of trouble when everything else electrical goes kerplunk.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 09-28-2009, 07:49 AM
TrutrakTech TrutrakTech is offline
Right on target!
Trutrak Tech Support
trutrakap.com
