Originally Posted by flyeyes
I would add here that _any_ handheld GPS "simulated" instruments are a poor substitute for a backup EFIS or wing leveler. This is especially true in an RV. An SR22 is vastly more stable than my RV-8.
well, I beg to differ, particularly so with a 496 that has a 5 Hz GPS engine, thus updating the backup GPS-driver instruments every 0.2 seconds, instead of 1 Hz (once per second) like the 396 and most other handheld GPS.
This very same topic was discussed a while back here:
http://www.vansairforce.com/communit...ad.php?t=29206
On the second serial port issue mentioned by breister, it was removed with the 396. I infer that this is the case because of XM Weather and radio. The hockey puck XM antenna output is a serial stream piped thru USB, and they have rerouted the connection internally in the GPS. Very easy to do for Garmin, and I assume that very few were using the second serial port on the 296 anyways...
Ciao, Luca
