Old 09-26-2009, 04:52 PM
glenn654 glenn654 is offline
Default Painted Canopy
Does anyone have any pictures of RV w/ the top the the canopy painted?
If so, please post or tell me how I can see them.
Thinking of a look like some SX-300s I've seen.
Glenn Wilkinson
Old 09-26-2009, 05:17 PM
Michael White's Avatar
Glenn Wilkinson
Glenn,
Here are a couple of pictures I took at LOE 2005, of Mel and Ann Asbury coming in. Hope this helps you out.
Best,
Moose
VAF #136
Old 09-26-2009, 08:52 PM
I have been in Mel's RV-6 and the painted canopy does not obstruct forward or side vision at all. Unless you strech your neck, vision upward it very good. I can image it is very nice on a sunny day...
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 09-26-2009, 10:02 PM
Thanks Moose, that's just what I had in mind.
If anyone has any others I'd like to see those too.
Looks like a good mod.
Glenn Wilkinson
RV-4
N654RV @ MLJ
Hey Mel,
If you are here, Did you paint the inside or outside of the plexi?
Last edited by glenn654 : 09-26-2009 at 10:05 PM. Reason: To ask a follow-up question
Old 09-27-2009, 07:30 AM
N130WN's Avatar
N130WN N130WN is offline
I've thought about doing this using vinyl "window perf".
See through to some degree and less permanent. Anyone else?
Larry Bowen
RV-8 Built, sold, missed.
RV-7 Built, sold, missed.
RV-8 Emp in progress ...
RV-8A Purchased, flying.
Old 09-27-2009, 04:11 PM
erich weaver's Avatar
Not sure, but your "window perf" may have some form of adhesive on it that is fine for glass, but not good for plexi. As an alternative, consider a tinted static cling windo shade. It can be cut to size and applied with a squeegy and an alcohol/water solution and a few drops of a clear or white liquid soap. Works great and dirt cheap.
erich
Old 09-27-2009, 04:26 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Default Don't do it....
I wouldn't do it! I'd much rather use a collapsible shade that's available for RV's. I have one. There are just too many times where a full canopy has it's benefits. All depends on time of year, the sun, etc. Personally, I prefer the open canopy in the pattern. I don't want to feel like I'm landing a Cessna where the runway may briefly disappear. I've also flown over high mountain areas at -6 degrees F., where the "see around & over" canopy acted like a comfortable greenhouse, while affording a much better view. Permanent style hardtop..........no way!
L.Adamson
Old 09-27-2009, 06:03 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
What Larry said!
With all due respect to Mel and others who have done this, I think it is a bad idea. It is very permanent solution to a very temporary problem. The Koger sun shade is very popular and will accomplish the same thing, but is easily retractable during the 50-80% of the time when it is not needed or even desireable.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 09-27-2009, 06:13 PM
ShadesOfGray ShadesOfGray is offline
It's funny to me how much more civilized the airplane looks with the painted canopy. It looks more like an airliner and less like an aerobatic plaything.
Old 09-27-2009, 06:38 PM
L.Adamson's Avatar
It does at that! I'd almost expect to see two more people sitting in the back!
L.Adamson
