Old 09-26-2009, 11:58 AM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Cleveland Parking Brake 60-5
Hi Evenyone-
I bought a Cleveland Parking Brake from Aircraft Spruce. It didn't come with any direction. So I have a couple of questions.
#1 - It has four nipples to connect inline with the brakes, and a direction flow. So which direction does the brake fluid flow?? I assume it flows from the pedal in the direction of the brakes on the wheel.
#2 - How much deflection in the actuator handle will hold pressure? And which direction of the handle is open vs. closed.
Any pictures of a previous install would be a big help. Thanks.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
Old 09-26-2009, 06:41 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Matco info
Not sure if the Cleveland parking brake is the same. Here is the info for the Matco parking brake.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
