Old 09-25-2009, 09:22 AM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Why have a switch on ALT Field?
I am brain storming here while I work on my electrical system design (Z12). I wonder why there is a switch for the Alt Field. From my reading on the forums internally regulated alternators get their life shortened if one turns them on under load, (they should be on before start until after start to get the most life out of the alternator). The B&C alternator is externally regulated and can handle the switching under load. But operationally there is no reason to switch the alternator on and off, if you have an abnormal situation and need to turn the alternator off you can do that just as easily with a circuit breaker as you can with a switch. So why not leave the switch out of the loop and wire the alternator field directly to circuit breaker so it is always on, in case of alternator problem, pull circuit breaker. On less switch a few ounces and dollars saved. So, am I missing something obvious here?
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 09-25-2009, 09:29 AM
hecilopter's Avatar
hecilopter hecilopter is offline
Default That's what
I would do if doing it over
Rusty "Rooster" Williams
N357RV RV-7A Tip Up (flying and Painted!) - 1560+ hrs.
Superior XP-360, carbureted, Hartzell 74" Blended Airfoil Prop
Grand Prairie, TX
KGPM
Old 09-25-2009, 09:34 AM
gasman gasman is offline
I have a PLANE POWER ALT. and that's how I did it. Been working great for 250 hours. And you don't need that split hard to install master switch. Drill another hole and install your master sw.............
rbibb's Avatar
rbibb rbibb is offline
If regulator fails youi can then shut off the Alternator. Of course fuse and/or circuit breaker will allow same thing. If you have crowbar overvoltage protection it will happen automatically.
Richard Bibb
RV-4 N144KT
Fredericksburg, VA
KEZF
Old 09-25-2009, 10:13 AM
N999BT N999BT is offline
Default You are probably already doing this but...
Be sure that when the master switch is off, so is the field circuit. In other words, if you are using an essential bus, make sure you attach it to the main bus, not the essential bus. If you can energize it from the essential bus, there would be current being used by the alternator even if it is not generating electricity.
If you are following Aeroelectric connection drawings you can run the field circuit throught the master switch and it shuts down the master solenoid and field circuit at the same time on separate circuits.
Brent Travis
N999BT
Flying
Old 09-25-2009, 11:12 AM
RVG8tor's Avatar
Default Clarification.
If you are following Aeroelectric connection drawings you can run the field circuit through the master switch and it shuts down the master solenoid and field circuit at the same time on separate circuits.
I am not sure I understand, if I have my alternator field going to just a circuit breaker on the main bus and it is IN, and I shut off the battery master (de-energize the main bus). I then turn on my E-bus alternate feed to power the E-bus from the battery. Would this cause trouble? If I need the alternator field off, I can do this with a switch or without the switch pull the CB. What I am asking about is wiring according to the AEC Z12 but I would not have the alternator field go to a switch it would just go to the main bus CB. My master switch would really be a "battery switch".
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2019
Old 09-25-2009, 12:28 PM
rocketbob's Avatar
I'm not using a ALT switch on my rocket. I have one in my RV-6, and in over 1100 hours of flying I've never found a need to shut the alternator off. Of course if you were flying on battery alone, you can switch the field off which would drop the 3A draw off the bus if you have the switch...but if your fuses or breakers are accessible then its just a simple matter of pulling the breaker to disconnect the field.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-25-2009, 01:54 PM
MCA's Avatar
MCA MCA is offline
Another reason is that if you have a primary and a backup alternator, you need a switch to select which one to use.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
Old 09-25-2009, 02:53 PM
kiwipete kiwipete is offline
Another reason, if your running the battery master but not the engine you don't have the drain of the alternator field.
Peter
RV7 G-PBEC Flying
RV10 Finishing
Old 09-25-2009, 03:50 PM
N184JG N184JG is offline
If you have an under or overvoltage system installed you can reset by turning off the field. It worked very well in my PA32 & 172 I have the split sw in my RV8.
Jim Gallaway VAF#782 2013 PAID 2014 paid
Gundys airport
Owasso,Ok
RV8A N184JG FLYING SOLD
RV7 N1717G FLYING sold
