09-24-2009, 08:38 PM
Exp-Bus DC Load Center? Any thoughts?
Does anyone have any experience with the load center that Vans sells. (EXP 2, rocker type).
Tony Phillips
N524AP, RV 9 (tail wheel)
09-24-2009, 09:07 PM
I'd vote no
The EXP-bus on my plane is the only component that hasn't lived up to my expectations. I've had to modify the wiring to prevent nusance trips on both the nav lights and strobes. The electrical anunciator volt indicator is off, and the amp indicator is inop (I've redundant indicators). Installation was just as complex as standard wiring, maybe more since I remoted the switches. If I wasn't so busy flying I'd rewire today. In retrospect, I would have gone with the Nuckles (I know, sp?) electrical method. Get the "Aeroelectric Connection" and follow his directions and you will have a bomb proof electrical system, and you will understand the concepts under which it was designed. I went with the EXP because I had no experience with electrical systems and I thought it would be easyer and cheaper. It was neither.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
09-24-2009, 09:12 PM
Thanks Bill. I appreciate your input.
Tony Phillips
09-24-2009, 09:21 PM
I used the EXPBUS on my first RV. I followed Nuckolls' on my second.
I agree with Bill that the annunciator amp indicator is poor, but nuisance trips with lights were not a problem as long as you read the docs, and use the proper switch positions to ensure you are using the properly-sized polyfuses.
I believe it does save time to use the EXPBUS, but I also now prefer the Nuckolls individual switch philosophy.
Roger, 7A, N374RS, Tucson
09-24-2009, 09:23 PM
I have the EXP 2 with the toggles switches.
I too went this route for the same reasons as Bill. It was confusing to setup as I was not familiar with the electronics terminology.
I've been flying over 3 years and have had no problems or issues.
But, I would probably go the Nuckolls route if I was to do again as it would provide more flexbility.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
09-25-2009, 05:02 AM
BUY a Vertical Power
Buy a Vertical Power, Marc's product is far superior. Having installed two of the exbusses and been very disappointed, and three VP-200s with no disappointment there is no comparison.
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
09-25-2009, 06:07 AM
I installed the EXP-bus in my -6A but operational experience has taught me...what's the point? At the time I thought it looked cool but that's about it. I will say this...located low on the instrument panel directly in front of me, at shutdown it is very easy to run my fingers along its row of rocker switches to verify everything is off. Still, I installed toggle switches with Klixon breakers in the -8.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
09-25-2009, 07:16 AM
I'll add my experience to the growing pile: I had one of these in my RV-9A (bought flying) and didn't like it. Wouldn't ever install one on purpose.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
09-25-2009, 08:58 AM
Works as advertised for me ...
Got one in the RV6.
Has worked as advertised.
I have a "sort of" split buss arrangement using the rightmost three switches.
(For those with one, supply power there via 2nd battery, so to speak as I actually take it from my one battery at a place where I can add 2nd later.)
THe three right switches power Autopilot, AUX power and Clearance Delivery.
I can run any of these with the master OFF thus the "alternate bus arrangement".
Per strong recommendation from Jeff Rose, the electronic ignition has a dedicated switch and fuse straight to the battery.
The Annunciator panel works. The charge/discharge may no be exact but it lets me know when things are working and when they are not.
I recommended this to a friend years ago and helped him with his installation. He has had no problems either.
If you want more info and pix let me know and I will send offline.
Having said all that, my second RV is designed around the Aeroelectric "Z-14" approach. Different plane, different mission, different requirements.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
09-25-2009, 09:44 AM
can someon elaborate on Nuckolls way? How does one learn more about that.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
