Old 09-24-2009, 08:29 PM
apkp777's Avatar
apkp777 apkp777 is offline
Default Switch/Breaker Labels
I am trying to decide how to label my switches and breakers. Any suggestions?
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 09-24-2009, 08:31 PM
apkp777's Avatar
Wow, it's late and I can't spell past 5pm. SWITCHES AND LABELS!
Tony Phillips
Old 09-24-2009, 10:38 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Our avionics company uses a local laser engraver for all text labels. It is the best looking and lasts forever. It isn't very expensive either. You may want to search for a laser engraver near your location. I've seen many do it yourself methods but I haven't seen any that are superior to the real engraving method.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 09-25-2009, 05:32 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default Labels
I used Aircraft Engravers for my labeling. Great folks, easy to get it done, and not expensive. Durable and very legible.
http://img15.imageshack.us/img15/2484/dsc2589j.jpg
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 09-25-2009, 05:49 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Decal Pro
I used the Decal Pro system - can be a pain to get the hang of but looks like silkscreening. Do a forum search for Decal pro.
Jim Sharkey
Old 09-25-2009, 07:14 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Search the forums for "Brother" and I bet you get a bunch of hits on threads talking about DIY labels. My experience has been that people generally change at least a few things on their panel between the time they lay it out and the time they fly it, so if you laser engrave it up front, you'll be changing something and need alternative labels before you're finished.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-25-2009, 07:31 AM
Dave_Boxall Dave_Boxall is offline
I laid out my panel on CAD& had it laser cut. I then drew up the labels in CAD, converted them to a JPEG file and had a Vinyl sheet printed at a local sign shop. I use a single sheet (goes on in one piece) for all the switches and individual labels elsewhere. Its also cheap enough that if you have to re-do anything you can get another sheet printed.
If your panel is black then you get the background Vinyl printed black (its a pretty good match on my panel). If I had my time again I'd paint the panel grey & get the Vinyl printed black on clear - My local sign shop can't print white on clear)
Dave
Dave Boxall
RV-9A / Wilksch WAM-120 diesel. Flying since April 09
Bath England
=VAF= membership dues paid April 2017
Old 09-25-2009, 10:35 AM
erich weaver's Avatar
I believe Stein had an article in Kitplanes awhile back outlining the different panel labeling techniques and their respective benefits and drawbacks. The best bang for the buck seemed to be customized rub-on lettering, with a protective layer of clear coat over the top when completed to your satisfaction. I think these are available through Spruce and others.
erich
Old 09-25-2009, 06:35 PM
apkp777's Avatar
Thanks for the replies. I will look into your suggestions.
Tony Phillips
Old 09-25-2009, 06:41 PM
johnny stick johnny stick is offline
Default use epoxyclear coat
The best thing I found for test equipment was to use rub on letters. When it is all done and you are happy with the labels, then coat the letters with clear epoxy. They will never rub off.
Johnny stick
Looking to start the RV10 in 2 years
