View Poll Results: Do you have to be cleared into Class D airspace?
Yes
8 |
10.39% |
No
69 |
89.61% |
09-22-2009, 01:03 PM
Airspace question of the day (9/22/2009)
Do you have to be cleared into Class Delta airspace?
It couldn't get much easier thant that.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
09-22-2009, 01:06 PM
Trick question...
This is sort of a trick question. My understanding is that you don't have to be cleared, like you do for class B. But that you have to have made radio contact with the tower. So I would say no.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
09-22-2009, 01:09 PM
Agree with the radio contact, in our area we have an old TRSA, which has an outer band at about 10 miles. Technically, if you are VFR you only have to contact the tower to enter the space and get clearance to land. We treat it as a mini class B, by contacting approach control then being handed off, finally to ground after exiting runway.
09-22-2009, 01:11 PM
Two way radio communication must be established. There is no permission/clearance required.
I say, "XXX tower, Experimental RV NXXX"
tower responds "RV NXXX, say position and intentions"
He repeated my N-number, two way radio communication established.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
09-22-2009, 01:12 PM
No CLEARANCE required.
Only have to establish 2-way radio communications.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
09-22-2009, 01:14 PM
Super Moderator
Don't mix up TRSA's with Class D. Permission to enter with TRSA's approach control is somewhat optional-- only radio contact has to be established.
Although someitmes you will hear "remain clear of the class C" upon contact.
For Class D airspace, you had better get permission to enter, depart, or transit the area during their hours of operation.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
09-22-2009, 01:53 PM
Just took the written...this is the way it is! Only establish radio contact. Radio contact at a minimum would be the controller saying your N number and standby.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
09-22-2009, 01:57 PM
I agree.
You do not have to be "cleared". However, you must be in radio contact with the tower. Meaning you have called the tower and they have acknowledged you by your full call sign. "Aircraft calling [insert name here] tower, please say again.", does not constitute "radio contact".
That being said, I think I answered "yes".  Subtract one from yes and add one for the no's.
Michael
Danville, IN
RV-7A Canopy/Finishing
N317PU Reserved
2020 Dues paid (February 2020)
09-22-2009, 02:06 PM
While this is true because of the way the FAR is written I would heed Vic's advice.
I imagine you would be in for a less than pleasant day if you called approach, they acknowledged that call with your N number, you asked for a radio check and then blasted across the primary airport in the Class D.
Milt Concannon
09-22-2009, 02:13 PM
Also, don't mix up a TRSA and Class C.
You don't need any permission to "enter" a TRSA as it isn't even classified airspace anymore and you won't find any FARs published pertaining to their regulation. Just establish communications to "participate" in the services it may provide in that area. Participation is absolutely optional.
Although sometimes you will hear "remain clear of the class C" upon contact.
Which is a whole other thing.
Vic
All just airspace 101 that any pilot is supposed to know real well. The longer I am around, the more I'm sometimes alarmed at just how many people are flying around without the required information stored. I've only been a pilot for 17yrs. I still have a lot to learn.
Sorry Vic, I didn't mean to pick apart your post. You're da' man.
Scott Card
CMW E-Lift
