Old 09-21-2009, 11:08 AM
zman zman is offline
Default Engine Shutdown Procedure
Anyone have any thoughts on the following procedure for engine shutdowns...
While at the Reno Air Races this last weekend (in the pits)...I noticedthat
many of the race aircraft after the race and taxi back ran-up there engines to a intermediate RPM for about 30 sec then cut the mixture to shut down the engine while at the higher RPM...I am guessing it was to keep the spark plugs hot an clean...I have and XP IO-360 on my RV-8 and think that this may be a better way to shut down and engine after a days flight...a run-up to 1500-1800 RPM then after 20-30 seconds... Mixture-Idle Cutoff...Any thoughts??
Zman
Old 09-21-2009, 11:15 AM
T6pilot T6pilot is offline
Thumbs up Lycoming Shutdown Procedures
The procedures for large radials/liquid cooled Merlins are different than for Lycomings. Recommend you go to the Lycoming website and obtain a copy of their operational procedures manual. It provides procedures for operation including shutdown. You generally can't go wrong following the OEM procedures. Fly Safe.
Randy
Old 09-21-2009, 11:24 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default A common reason is
Oil scavenging for dry sump, at least for the radials.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-21-2009, 11:28 AM
wera710's Avatar
wera710 wera710 is offline
On the Lyc its not a bad idea to lean aggressively on the ground once you are taxing back to the hanger. Then, before shut down, run her up to about 1200 rpm for 20 or 30 seconds, then go to idle cut off. They lycomings run pretty rich on the ground.
Scott "Lawbreaker" (yeah, its a fair cop!)
RV-8 N710PX "Bad Attitude!"
Old 09-21-2009, 12:22 PM
plehrke's Avatar
plehrke plehrke is offline
If you lean agressively on the ground you do not need to bring the temp up (increase rpm) just before shut down (my opinion). I lean to the point of engine dying (and then push in a tad) while taxing in and out from a flight. Never have had spark plugs fouled or rough run-ups.
Leaning or running up is done to get the temps up to allow a better burn and activate the lead scavaging agents in the fuel. I have heard that you want to get the EGT to over 1100F. Lycoming recommends the run-up to 1800 rpm for 15-20 sec. See page 66 of the Lycoming Flyer (page 32 of the pdf file)
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 09-21-2009, 12:29 PM
jetjok's Avatar
jetjok jetjok is offline
Default Right Again, Mike!
The reason for the run-up on radials and the Merlins is to scavenge the oil from the lower end of the engine prior to shut down. These engines have "dry sumps" meaning that they have a remote oil tank.
It looks and sounds cool, but we certainly do not need to be doing that with our Lycoming's for the reasons stated in previous posts.
Mark Ohlau
RV-6 N506MM VAF #1410
2017 Donation Made
Old 09-21-2009, 12:39 PM
SteinAir SteinAir is offline
Not only for oil in the sump, but many Ham Standard c/w props also recommend shutting down in high pitch which also forces the oil out of the cylinder and back to the tank along with all the other oil being scavenged back to the tank.
Me in the RV....most of the time I just pull the mixture as I'm rolling up to my hangar. By the time I reach the hangar the engine is stopped and if I do it right I'll have exactly enough momentum to just swing the tail around ready to push in the hagar!
Stein
Old 09-21-2009, 12:41 PM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by SteinAir View Post
Me in the RV....most of the time I just pull the mixture as I'm rolling up to my hangar. By the time I reach the hangar the engine is stopped and if I do it right I'll have exactly enough momentum to just swing the tail around ready to push in the hangar!
Stein
Trained by Bob Hoover????
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-21-2009, 12:44 PM
Mike S's Avatar
Senior Curmudgeon
Default tip
Just a tip for those who fly with mags---
Right before you shut the engine off, at idle, shut the ignition off for a short while, just a quick off, and then back on. Then use the mixture to shut it off as normal.
If the engine FAILS to shut off while the ignition is off, you have a bad mag ground ---"P"---lead, and a HOT mag.
Fix it soonest, a hot mag can really spoil your day.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-21-2009, 02:02 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Mag off-on issue
Turning mags off on a running engine, then back on can cause a **** of a backfire. I'd strongly suggest only doing one mag at a time.... don't turn both mags off at the same time. "Been there done that"
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
