Old 09-19-2009, 06:27 PM
rwarre rwarre is offline
Default fiberglass
Working on the rear canopy fairing on my 7a slider. Would like any tip on how to get a nice finish with the fiberglass. I have a pretty smooth surface but have a few voids which need filled in. Thanks
Old 09-19-2009, 06:43 PM
Erik Westlund Erik Westlund is offline
Default surface
fill the voids with whatever filler you're using most guys on this site use evercoat. sand the surface to like 80 or 150 grit. then I prime with a epoxy sanding primer I'm using the ppg 7650 gray primer. cause I know that we are going to use ppg finish primer and paint to finish. then usually you can sand out the primer with like 220 and be ready for finish prime and paint.
happy building
Erik
RV7
Empennage done
Wings done
Quick Build Fuse
wiring & finishing fairings
