Thanks Pat!!
OP-35 kind of matches the out of the box holes, thats the
IO-320/360 drawing. For the heat, going to have to make that work since its already there and it's 2"!
Fingers crossed that "carbed" cable lengths work with these holes...again, they're already there. Not sure which hole is for which cable, but will probably be obvious with the engine mounted.
The transducer manifold is the other issue for me because the hoses may differ in length based on vertical/horizontal orientation and carb vs FI. Which engine are you using?
Joe
