09-19-2009, 05:47 AM
Any danger from flying without spinner?
Long story to short - it would be convenient for me to fly a short distance without my spinner (today).
anyone know of good reasons for not doing that?
Steve Brown
N598SD - RV9A second owner
O-320, 9:1 pistons, Catto 3 blade
KRHV - Reid Hillview airport, San Jose, CA
09-19-2009, 06:26 AM
There is a lot of air entering the cowling without a spinner. If you have to fly I would do it at low speed.
JMHO
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
09-19-2009, 06:52 AM
If your backing plate has sections riveted to it that fill the gap behind the prop when the spinner is in place, you might want to remove it. Otherwise there is a good chance the centrifugal force will rip those parts right off the backing plate. This happened to the RV-6A two hangars down from me while he was doing a ground run.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
09-19-2009, 07:17 AM
Centrifical force ripping the backplate assemply apart? Are you kidding?
That backplate came apart for other reasons.
I have hundreds of hours in both my RV's with no spinner and backplate installed. No speed or cooling changes. None.
Id fly it!
Kahuna
6A, S8 ,
Gold Hill, NC25
09-19-2009, 07:23 AM
Kahuna, what can happen is the little aluminum pieces that fill the gap behind the propeller blades can come off - rip off in fact. This is what Bill R was talking about.
Happened to me once and it was at a fairly low speed. I think it was a combination of centrifugal force and air loads building behind the plates. Each plate had 3 AN3 rivets in it and they both tore off exactly at the same time.
Agree, the spinner has no effect on performance (or not much at all).
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
09-19-2009, 07:38 AM
Ahh. Gap filler peices. OK I get that. I read it the backplate came apart.
I conider the gap fairings part of spinner, not the bacplate.
I have personally flow a dozen RVs with no spinner. Guys do it all the time. Fixed or c/s.
Even with the additional speeds of the Super 8. No problem.
Kahuna
6A, S8 ,
Gold Hill, NC25
09-19-2009, 07:49 AM
If it has those filler pieces..
...just safety-wire them together. My Cessna 310 had a spinner unwrap itself on a trip and we flew from Mississippi home with safety wire holding those pieces in.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
09-19-2009, 08:06 AM
wrong rivets used?
Quote: "Each plate had 3 AN3 rivets in it and they both tore off exactly at the same time."
My prints say to use 4 AN4 rivets.
Five Sierra Fox
RV-9A
Utah
09-19-2009, 09:48 AM
There is also another, more insidious danger.
Flying without the spinner will get you ridiculed for flying an ugly airplane. This will occur for many years following the event...
09-19-2009, 07:22 PM
Blah Blah...
Flying without a spinner... no big deal at all. It's been done for years.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
