Old 09-18-2009, 01:45 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Default Throttle/mixture cable length for RV-9A IO-320
I attempted to route and pre-connect the throttle and mixture cables today for my RV-9A with an XIO-320 engine with the Precision Airmotive injector body (all from Vans) and the supplied cables were way too short, by at least 6" and probably 8". Anyone else run these cables with this engine/injector who can give me a sanity check before I order new cables?
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 09-18-2009, 09:12 PM
Dan B Dan B is offline
I have the 9A with the YIO320D1A from Vans. My cables are installed. Cables with the firewall fwd kit are adequate. I think they are the longer cables that Vans sells. Check that your cable length is correct. Routing of the mixture cable through the firewall was a guess because the location identified in the plans is for the IO-360 engine. I used the approximate firewall location as for the carburetor.
Dan
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
Old 09-19-2009, 10:08 AM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Control Cable lengths
I ran into similar problems with my -9A; IO-320 installation. Prop cable was OK, but I had to exchange the mixture cable that came with my FWF kit with the longest one that Van's carries (51.5"), and had to special order an even longer Throttle cable from Aircraft Spruce, that cost twice as much and was NOT returnable!
The problems arose from installing the controls IN the PANEL rather than the under panel F-746. That alone pulled the cables Aft by several inches. There are numerous variations that can result in the cables with the FWF kit to not be "optimum" length.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
