Actually you need to look carefully at the Type Certificate sheets for your prop. The current (7497?) prop (a la Vans) doesn't have limitations for the 180 hp engine if the engine is completely stock (mags, etc...) but if you change compression or use electronic ignition, etc... then you will have some sort of limit (probably hard to specify it).
As for the basic engine limits, you can look up redlines etc... in the Lycoming manual. What I've done is start with pretty conservative numbers and then tweak after flying for a while.
For example.
I REALLY don't want to push my CHT's over 400 F although the redline is 500 so I put the yellow down to 400. If it gets their I start speeding up the climb or whatever.
I also would like to know about oil temp at 200 F. Same sort of thing.
Originally Posted by AirbusPilot
Hi All,
Also I understand that my prop engine combination does not have rpm limit or not recomended rpm.
Waiting for your advice
