Old 09-18-2009, 08:29 AM
Noel Simmons's Avatar
Noel Simmons Noel Simmons is offline
Thumbs up Blue Sky Aviation
I wanted to post about some of the things we are doing here at Blue Sky Aviation.
Currently we are finishing up our 37th airplane it will be an RV-7 with the IO-390 from Lycoming. In the panel we have the Vertical Power VP200 and the dual HX?s from GRT, and of course heated leather seats from CAD (it is cold here in MT).
I got bored one day on January 1 and decided to start my own injection molding company which has a 3D scanner, 3D CAD SolidWorks, GibbsCam, to run the HAAS milling machine, and an Arburg injection molding machine.
What I can, and have done, is scan some part like the cowling, create parts and molds for the parts.
So far we have CNC milled rudder bar extensions so you can be sure you are not riding the brakes. These just clamp on with 4 screws, takes about 10 minutes at a weight of just a few ounces, is a no brainier for RV-6-7-9-10?s.
Custom designed panels that we either water jet or mill. All the mounting holes radio rack brackets and their corresponding holes drilled to the correct size. For this last panel with the VP-200 I made a 15 degree wedge for the so the pilot can see VP and the EIS, the aluminum radio rack support was molded into the side of the wedge to preserve space on the panel.
Molds for the carbon fiber oil cooler plenum (fiberglass where we expect to touch aluminum) for the Airflow Oil cooler that we mounted on the firewall, weighs 2.8 oz. This will work with RV-6-7-8-9. When using a heavy engine it helps move the CG back a little, saves the baffling from being beat to death and is the correct size oil cooler for the bigger engines.
Molds for the intake and filter housing that replace the Van?s snorkel. This will work on the RVs with the forward facing induction systems. This is more of a ram air system, uses the Van?s K&N supplied filter, and is MUCH EASIER to install. AND did I mention you don?t have to modify the baffling and or support the much heavier snorkel with the baffling.
I would like to solicit ideas from the forum to build for the RV?s, NO job to big or small, plastic, metal, fiberglass, Carbon fiber, or wood, it does not matter. My ultimate passions is to one day (sooner than later) is to design my wooden glider and become a member of the Experimental test pilots association
Thank you
Noel Simmons
Noel Simmons (repeat builder) just ordered my 40th it's an 8!
406-538-6574
A&P CFI EAA Tech/EAA flight adviser
Old 09-18-2009, 08:40 AM
hydroguy2's Avatar
got any pictures of your oil cooler plenum? I didn't see any at your site.
sending you a PM about other stuff
Old 09-18-2009, 11:47 AM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Default Snorkel replacement
I would like to see some information and pictures of your snorkel replacement for forward facing air induction. If you could PM me or send me an email off site I am interested in seeing what you have in regards to this.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 09-18-2009, 12:41 PM
nucleus nucleus is offline
Lightbulb Empennage Fairing that Fits
Noel, how about a empennage fairing that actually fits out of the box?
Hans
Dr. Hans Conser
Bozeman Chiropractor
RV-6A 195 Hours, up for sale soon?
Old 09-18-2009, 12:47 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Default Air induction mod...
As am I! First glance looks like a retrofitted Rocket intake.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 09-18-2009, 01:01 PM
RVbySDI's Avatar
Where are you seeing your "first glance"? I have not seen anything on the website pertaining to this snorkel replacement.
RVBYSDI
Steve
RV9A
https://rvwings.com
Old 09-18-2009, 01:13 PM
hydroguy2's Avatar
Watch the video of the RV-7 on BlueskyAviation front page
Old 09-18-2009, 01:19 PM
Also noted here...http://www.vansairforce.com/communit...17&postcount=2
"I also have improved the air intake as I like the Rocket looking intake so you can see the one I made molds for on my web site" - Noel
I've always like the smiley of the Rockets as opposed to the pop can hole opening of the stock intake.
Carlos in Arizona
Old 09-18-2009, 07:28 PM
Geico266's Avatar
Geico266 Geico266 is offline
Noel, I tried to find your brtake peddle adapters on line, but when I click on the peddle it takes me somewhere else. Please check the links on your web site.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-19-2009, 08:03 AM
Default nose to the grind stone!
Yesterday was a full one! I did not get a chance to send picturs to the folks that I promised pictures to
Yoshie will work on the link for the break pedals this week end. the link takes you to Y's Engineering which is the company we started to make things like this.
406-538-6574
