09-18-2009, 06:36 AM
vans tach transducer
i've been reading on old threads about how to feed tachometer data to the Dynon EMS. I have one Mag and one Lightspeed, and ideally would like to have the tach work regardless of which is firing. Apparently Vans' Tach Transducer will work. I presume this is the one I want:
IE VTACHGEN 2 (i have no vacuum pump on my engine).
http://www.vansaircraft.com/cgi-bin/...duct=vans-tach
QUESTION - how does this thing work? how does it get installed?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
09-18-2009, 06:53 AM
It mounts on the tach drive hole.
...and gets spun by the gears, sending pulses to the gauge.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
09-18-2009, 06:56 AM
Ahhh... didn't know there was such a thing. Where abouts is this on a typical O-320?
Phil
RV9A (SB)
Ottawa, Canada
09-18-2009, 09:41 AM
The tach drive is top center on the accessory case. Depending on which oil filter adapter you have, either connect the vtachgen with the supplied adapter or purchase the 12" extension cable from Vans and mount the vtachgen on a nearby engine mount tube.
Five Sierra Fox
RV-9A
Utah
09-18-2009, 02:35 PM
would someone have a picture of this, as I need to work this out on my 0-360.
Thank you
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
09-18-2009, 11:02 PM
Mount it on the side of the FW recess, it's better for the cable.........
09-19-2009, 08:24 AM
I know a -7 builder who ran his vtachgen extension cable through the firewall so as not to bend/flex it. It's a clean looking installation, too.
Five Sierra Fox
RV-9A
Utah
