Old 09-17-2009, 07:40 AM
prkaye prkaye is offline
Default Emergency airspeeds
I realise that this data has to be validated by flight testing, but as an initial guide, can anyone point me to airspeeds for emergency operations (for the -9A)?
Specifically:
Engine Failure After Take-off (flaps up, flaps down)
Airspeed for Maximum Glide Range (flap setting?)
Airspeed for Maximum Glide Endurance (flap setting?)
Precautionary Landing With Engine Power
Landing Without Engine Power (flaps up, flaps down)
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-17-2009, 07:45 AM
bkilby's Avatar
bkilby bkilby is offline
Default POH's
http://www.vansairforce.net/poh.htm
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
Old 09-17-2009, 09:02 AM
terrykohler terrykohler is offline
Default Aircraft Performance
Phil:
Please look carefully at the numbers posted in the POHs listed on the web site. For example, the 9A in the data bank shows manuevering speed of 115 knots, and also shows an engine out table that was evidently taken from a 6 or 7 model with a constant speed prop. Many of these books have been put together by the cut and paste method rather that thru testing. This particular 9A also shows a best glide that I find suspect. Please proceed accordingly. You need to generate your own numbers.
Terry, CFI
RV-9A N323TP
Old 09-17-2009, 09:05 AM
I believe that is 115 mph in that POF, which is pretty close to the value published by teh CAFE report...
Phil
RV9A (SB)
Ottawa, Canada
Old 09-17-2009, 09:36 AM
az_gila's Avatar
az_gila az_gila is offline
Question Since the manuevering speed...
Originally Posted by prkaye View Post
I believe that is 115 mph in that POF, which is pretty close to the value published by the CAFE report...
...is related to structural issues, shouldn't you start with the 118 mph number from Vans, and then adjust it for any IAS correction during testing?
In this case, Vans number should trump CAFE testing...
http://www.vansaircraft.com/pdf/speeds.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-17-2009, 10:47 AM
Default POH Reliability
Phil:
Look at the operating limitations for the 9A listed on this site. Va is 132 mph. Where do you think all of these numbers came from? Unless you've got a fair amount of experience on the stick, I certainly wouldn't want to bet my life on them. Look carefully thru this handbook. All the numbers appear to be copied from something other than a 9 model.
Good Luck
Terry
