09-15-2009, 12:16 PM
Fuel tanks
Does anyone know the name of the company that builds RV fuel tanks, they are in Lakeland Fl? Thanks Tom
09-15-2009, 01:30 PM
Hi Thomas...
...my buddy, Ray Lawrence builds RV tanks...he's done dozens. Located at Sandersville, Ga, runs the FBO there. 478 232 9560.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
09-15-2009, 05:14 PM
Building the tanks isn't that bad - I'd at least try it before parting the work out...
Jason Klovning
RV8A fuse
Platteville, WI
09-15-2009, 06:54 PM
If I can do it anyone can...
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
09-16-2009, 04:12 AM
re: tanks
I had a little help, I think 2 or 3 friends, building my RV10 tanks. I thought it was kind of fun actually. None of us are all that anal about the proseal, acetone, mek, suit-up/glove-up, whatever. We did use rubber gloves to keep the stuff off our fingers and making a big sticky mess. But over all, it was kind of enjoyable, really. BTW, all the helpers were RV builders or were finished building.
You might give it a try before you farm it out, you might find you like it.
But then again, I'm kind of cheap.
Marshall Alexander
RV10 N781DM
09-16-2009, 06:56 AM
OK, you expert tank builders, I have a question.
I have the materials to build new tanks to replace the quick built paint blister producing units now installed. (yes, new blisters are continuing to appear - the tanks were built in 2002)
The first part of the build process is to match drill the Z brackets to the spar sheer web while the bottom wing skin is not yet installed (if I read the instructions correctly).
Obviously, if the tanks are built by someone else not local this is not possible - the tanks arrive built without the Z brackets matched drilled to the wing. Am I correct in assuming that these brackets can be match drilled to the existing holes after the wing is closed out?
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
