Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 01-12-2007, 11:50 AM
the_other_dougreeves the_other_dougreeves is offline
Originally Posted by robertahegy
They may be working on a composite electric C/S prop for Rotax engines. They recently came out with a very nice looking ground adjustable composite prop for Rotax engines. The market is there and they may be jumping into it.
Roberta
I'd like to see another offering for a US-made CS prop for the 912 and Jabiru engine class. Making the prop electric adjust would be good for retrofits to engines that don't have CS provisions.
The Sensenich composite ground-adjust prop for the 912 and Jabiru 3300 is getting good reviews, and the CS should be a good unit.
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 01-12-2007, 12:33 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The 912 has provision for hydraulic C/S props as well a hollow redrive shaft for manually in-flight adjustable props as fitted to some CT aircraft.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 03-29-2008, 05:48 PM
Andre Kerstens's Avatar
Andre Kerstens Andre Kerstens is offline
Does anybody have any experience with the IVO prop and the electric governor they sell? I'm probably going to put an Egg H6 on my RV-7A and this prop looks pretty interesting.
Andre
Originally Posted by cobra View Post
Too bad you Lyc boys can't use the electric in-flight adjustable composite Ivo Magnum prop. It works well with most "smooth running" alternative engine, like the Subi and Rotary. http://www.ivoprop.com/inflightmagnumodel.htm
The prop is claimed to be good to 700 hp, adjustable pitch between 45"-105", and diameters between 58" and 76", weight around 25 lbs.
2 blades: $2100, 3 blades: $2340, 6 blades: $3220
Andre 'Flying Dutchman' Kerstens
RV-7A (N133MT reserved)
Taxi testing
http://rv7a.tauker.net
Old 03-29-2008, 09:06 PM
SteinAir SteinAir is offline
Andre
I got my index finger amputated by one last fall....does that count?!?
To answer the rest of the question, one my techs just bought a 2 blade Ivo Magnum for his Rotec Radial. I guess it's an "OK" prop, but after being around all the other normal props, both them and Warp stuff are a little scary to me (and yes...I felt that way before my hand got caught in one). I guess they work ok on a lot of engines and have been around awhile so that must speak for something. But if it were me and I had a higher HP engine, I'd probably look at whatever Jan has been and is using. The MT and Sensenich stuff he uses are built more like what I'm used to seeing. If you get a chance to see the Ivos and Warps dissasembled and then compare them to the MT's and Sensenich/Quiti that Jan uses you'll find there is a world of difference. Probably not a huge deal at 80hp, but at 200hp....who knows!
Just my 2 cents as usual and it's just my personal opinion above - not professional. If I were installing a Subie, I'd use what Egg recommends - for all the debate that exists, he does have more experience than the rest of us when it comes to this stuff.
Stein
Old 03-29-2008, 10:03 PM
rv6ejguy's Avatar
Andre
I've got 235 hours on an IVO Magnum with zero trouble. Takeoff and climb are impressive but I have a gut feeling that cruise is not as good as it would be with an MT. Is that extra potential 10 knots worth another $8K? Not for me. This thing is light too at only 27 lbs. which will help your C of G. I have no regrets for what I paid.
I don't have the C/S box on mine so I can't report on how well that works. I have a friend with a Magnum on his turbo Subie Glastar who just started flying a few weeks ago. I think he has the C/S box. I'll ask him how he likes it.
If you order one, be sure to get the 76 inch 3 blade 45-105 inch pitch range. The 30-90 is not suitable for an RV with your H6.
Stein is right, these things are very sharp. I did a Homer one day as I stood up quickly and really scraped my back on the tip. That did some serious damage.
Old 03-30-2008, 04:52 AM
Thanks. Appreciated your replies. I'm just at the beginning stages of getting a feel for what's on the market: engine-, prop- and everything-wise :-)
Taxi testing
