Old 09-12-2009, 05:00 AM
PaigeHoffart PaigeHoffart is offline
Default Taxi light in cowl inlet?
Anyone have any experience with mounting a taxi light on one of the inlet ramps? I've seen a couple of photos, and it seems like a simple solution that wouldn't require any cowl mods. I'm just wondering what kind of effect it would have on cooling.
Paige
Old 09-12-2009, 05:27 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Cooling and Vibration?
Any blockage in the air inlet could cause cooling problems.
Also our flying club has two C172s - one with lights in the leading edge and one with lights in the cowl. We are for ever replacing bulbs in the cowl mounted lights due to vibration damage and to my knowledge we have never replaced bulbs in the wing mounted lights.
Just my 2c
Jim Sharkey
Old 09-12-2009, 08:29 AM
Jim,
Thanks for the reply. The cowl mounted vs. wing mounted debate has played out. I'm planning on using both with a LED based taxi light to fill in the area immediately in front of the plane. The question is do I cut into the cowl, do some glass work, and then have to mess with a wire connector every time I pull the cowl, or can I get away with putting it in the inlet. Surely someone on the board has to know someone with the setup depicted above (http://k53.pbase.com/u17/sonex293/la...4.IMG_0667.jpg).
Here's a pic of the light I'm thinking about using:
900 lumen according to the specs, cast aluminum, and about $55.
Paige
Old 09-12-2009, 10:01 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Think first...
Before you do something so uniquely clever.
In the cowl inlet you have cooling issues. What will the light be shining on? Hmmm. Is that really what you want?
Old 09-12-2009, 10:07 AM
Robert M's Avatar
Robert M Robert M is offline
Default lights in cowl
I too flew a C-172 that had the landing light in the cowl - was always needing replacing. Had to make a night landing one time and light did not operate. a bad thing if landing at night
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 09-12-2009, 10:16 AM
Shockwave's Avatar
Shockwave Shockwave is offline
The link doesn't work for me, I get an access forbidden message.
Chanler Childs
RV-8A
Empennage complete
Building wings
Old 09-12-2009, 11:44 AM
terrykohler terrykohler is offline
Default Risky
The inlet area has been pretty much reduced to minimum section for sufficient cooling. If you search thru the forums, you'll see that efforts for further reduction have been made in search of more speed. Little to no success on the speed end, and increased problems with engine cooling. Putting your engine at risk for a center mounted light is probably something you should avoid. I have one light (standard duck-works wing mount) with a higher output bulb that is sufficient for taxi and landing. No plans to add another.
Terry, CFI
RV-9A N323TP
Old 09-12-2009, 12:02 PM
Hence the reason for the question. I too have reservations about the possible cooling effects, but there is at least one RV out there with the setup. I'd love to hear a "I tried it, but my CHT's went up 50 deg" or "works fine for my O-320...". Just looking for some empirical data, it's not my original idea.
Ummm... the same thing every other cowl mounted light would shine on.. the prop? What am I missing?
Paige
Old 09-12-2009, 01:46 PM
Shockwave's Avatar
A slightly tangent thought would be to mount a clear plate to the cowl and mount the light to a part of the structure and just shine through. You wouldn't have to worry about unwiring or unplugging it when you drop the cowl. It'd be much easier to aim the beam too.
Chanler Childs
RV-8A
Empennage complete
Building wings
Old 09-12-2009, 01:54 PM
The thought has crossed my mind. I think the light would have to be fairly close to the cowl to get a wide field of light without a huge lens. The easiest place to mount it would seem to be directly below the inlet ramps but, I worry about difficulty in removing the cowl due to interference from the lower inlet flange. If someone has pics of a setup like that, I'd love to see them. So far the only one I'm aware of has an aluminum bracket mounted to the cowling.
Thanks for the ideas,
Paige
