Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Autopilots
  #31
Old 09-14-2009, 02:48 PM
N999BT N999BT is offline
Originally Posted by Bill Dicus View Post
Haven't flown it yet but it's my understanding that the AFS EFIS with ARINC adaptor (which I have) can send output to the IIVSGV so it can fly ILS/VOR/LOC approaches. This seemed an economical way to obtain the capability. Anybody out there flying this combination successfully? Bill
I have an SL-30 Navcom connected to the AFS, an Airinc adapter, and the Digiflight II VSGV. ILS, VOR, LOC approaches work fine. I usually use the the AP when practicing, but when I do it for real, I haven't been able to just trust the electrons. Plus I like to fly them by hand.
Brent Travis
N999BT
Flying
Old 09-14-2009, 04:51 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Originally Posted by breister View Post
The Garmin 430/530 apparently do not output VOR/ILS data on either ARINC nor Serial in a format which the TT understands. This is a pity - it means you cannot even perform a LOC approach coupled unless the signal is processed first through a system such as the GRT EFIS.
The Garmin 430 absolutely outputs VOR and ILS data in ARINC-429 format. The SL-30 does it in serial. If an AP manufacturer wants to fly a VOR or ILS, all the data they need is already there, and in fully published formats. ARINC or Serial is the only connection we (Dynon) need to fly a VOR or ILS. The limitation is not a Garmin or hardware limitation.
Old 09-14-2009, 08:40 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Smile
And from our 530W it flies it very well indeed
Old 09-15-2009, 06:15 AM
Brantel's Avatar
Brantel Brantel is offline
Yeah but then they can't charge you for the outdated and expensive analog interfaces and the premium for the extra programing.
Now Dynon on the other hand needs to get off their duff and use this to their advantage in the AP76 for the thousands of "Current Generation" products out there in the field!
"ARINC or Serial is the only connection we (Dynon) need to fly a VOR or ILS" If only you had the AP76 to make good on this statement (disregarding the SL-30)
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 09-15-2009, 07:16 AM
Rick S. Rick S. is offline
Todd,
Being an owner of the RV-10 AP, GNS 480 and an SL-30 If I had to do it all over I would have climbed all over the Sorcerer if only to take advantage of the added features and the features of both Nav/Comm's. That said, I found a great deal on my RV-10 AP, which is why I bought it, and it ROCKS!!! Now if I was energetic enough to yank my panel to install the ARNIC adapter on my AFS 3500 I could control it from the EFIS, currently I use the 480 to feed the AP. Now that is a good thing because the guys I know that have 480's in their certificated mo'chines understand it's capability and know how to use that capability drool over the Trutrack's capability....and PRICE . If you decide to go with the RV-10 AP.....If at all possible dig a little deeper and go one more step up...you won't be disappointed.
Rick Sked
Old 09-15-2009, 08:59 AM
KPmarc KPmarc is offline
To clarify on the 430 Arinc/analog discussion. It's my understanding that the straight 430 does not output VOR/LOC/ILS onto any digital stream; analog only. But the 430W does have the Arinc stream containing the VOR/LOC/ILS data, and a separate Arinc GPS stream.
Marc Cook, Editor in Chief
KITPLANES Magazine
Old 09-15-2009, 09:42 AM
mburch's Avatar
mburch mburch is offline
Not quite sure that's true... both the WAAS and non-WAAS 4xx/5xx units on my desk will happily output VOR/LOC/ILS data via ARINC 429!
cheers,
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 09-15-2009, 09:45 AM
I stand corrected. My info came from a fairly famous avionics shop, who must also stand corrected!
KITPLANES Magazine
Old 09-15-2009, 09:52 AM
Brantel's Avatar
Shhhh.. TT does not want anyone to know that it would just take some software changes to make all their ARINC enabled AP's talk to the Nav side of the 430/530/430W/530W....Keep that quiet!
Old 09-15-2009, 10:10 AM
breister breister is offline
The data may be there, but the TT does not know how to "read" it - thus my comment "...in a format which the TT understands."
I rather suspect that due to competition from vendors such as yourselves they will rectify that in the future. When they do, I would be grateful if they offer it as an upgrade for my Digiflight II VSGV. I should then be able to install a switch to select between GPS and VOR/LOC from my GNS 480, since my Dynon EFIS does not provide the nifty interpreter feature to drive my existing autopilot the way other vendors do...
Competition is a wonderful thing!
