Old 12-28-2005, 02:50 PM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Installing Van's static kit
Any ideas for how to get the plastic tee fitting to fit on the hard plastic 1/4" tubing in Vans static kit? That is a really tight fit. Can't push the tube on but about an 1/8". Suggestions? Also, I have seen builders put a loop at each static vent (left and right sides) before routing to the panel. Vans' instructions, which illustrate the RV-6 do not show any loops. Wonder what the loops are for. Seems the loops would trap moisture instead of letting it drain back out. Thanks!
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 12-28-2005, 03:33 PM
dan's Avatar
dan dan is offline
Default Hot water
Dip the tubing in hot/boiling water for a second or two.
)_( Dan
RV-7 N714D
http://www.rvproject.com
Old 12-28-2005, 03:45 PM
flyeyes's Avatar
flyeyes flyeyes is offline
FWIW I did the boiling water thing when I first installed my Van's static system, about 6 years before first flight. I recall them being fairly stiff, but doable.
However, when doing flight testing I had a 4% error in my IAS (high) and variable altitude readings when making low passes at various airspeeds.
While tracking down the static leaks I find all of the tubing originally in Van's kit had become brittle and cracked. I replaced it all with polyethylene tubing (like Lowe's sells for icemaker plumbing) which was quick, easy and cheap.
If I were doing it over again, I'd just use better tubing the first time. Note the crack where the tubing has popped off the "tee."
James Freeman
Old 12-29-2005, 04:58 AM
Highflight Highflight is offline
Here's a note Phil B. made about his install where he did make a water trap and had to redo it to make sure it would drain properly. This might help you, and note that he has a linked photo of his install.
http://www.myrv7.com/viewnotes.php?noteid=41
RV7-A - Slider (QB Fuse and Wings)
Mattituck IO-360 (AFP) w/2 P-mags
Catto 3-Blade
SJ Cowl and Plenum
Panel: Dual GRT EFIS / EIS4000 / PMA8000B / SL-30 / SL-40 / Internal GRT GPS / GTX 327
