Old 09-09-2009, 11:48 AM
AX-O's Avatar
AX-O AX-O is offline
Default Rivet spacing for Sam James cowl
Guys I need to rivet the -5 piano hinge to the bottom cowl. The instructions say to rivet it however; they don?t give the rivet spacing. I started with a one inch spacing (on the same line) then researched a little a found that some people were riveting in somewhat of a ?V? profile (kind of like ? , ? , ? , ? , ?). Is there a preferred way due to the fact that the -5 hinge is so wide?
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 09-09-2009, 11:16 PM
tcone1's Avatar
tcone1 tcone1 is offline
Axe,
why rivet it at all? I'd scuff it and bond it using epoxy and micro. Use the 1 inch rivet spacing for the clecos to clamp it while glueing.
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 09-10-2009, 12:47 AM
AX-O's Avatar
Originally Posted by tcone1 View Post
Axe,
I guess I was just following directions for once.
Axel
Old 09-10-2009, 09:36 AM
ArVeeNiner's Avatar
Last night I riveted the third of the the four long hinges on my SJ cowl. I used 1" spacing just like the Van's instructions says and lined the top and bottom holes up. You won't notice the rivets once it's painted.
I also epoxied the hinge in place AND ran a strip of fiberglass along the entire hinge on the inside. Yea, that's probably overkill but I wanted to play around a little bit with laying and wetting fiberglass in an inconspicuous location.
They seem pretty secure.
Kelly Johnson
San Jose, CA
RV-9A
Pink slip issued: 5/7/12
Phase I Complete: 8/18/12!
2020 donation: complete
