Old 09-08-2009, 09:47 PM
Erik Westlund Erik Westlund is offline
Default Oil Door hidden latch
Here's some pics of our oil door latch system.
-E-
http://[/IMG]
http://
http://[/IMG]
http://[/IMG]
RV7
Empennage done
Wings done
Quick Build Fuse
wiring & finishing fairings
Old 09-09-2009, 01:32 PM
cropdusterengineer's Avatar
cropdusterengineer cropdusterengineer is offline
Default cool!
Does it spring open? Or do you just use your fingernail to pull it up?
I like neat, trick stuff on airplanes!
CDE
Old 09-09-2009, 01:54 PM
N8RV's Avatar
N8RV N8RV is offline
I've considered getting rid of my Camlocs and using a hidden latch system. However, I had planned to insert the hinge pin from the baggage compartment, and have the pin retainer in there (RV-8).
While that would necessitate having to unlock the baggage compartment whenever I wanted to open the oil door, it also means that I don't have to stick my hand into a HOT cowl inlet to reach the pin. As clumsy as I am sometimes, I think that's a good trade.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 09-09-2009, 02:27 PM
Pilottonny Pilottonny is offline
Cool Simple and cheap!
I like the idea: simple and cheap.
I guess it can not "spring"-open. How would you be able to lock it?: One hand holding the door closed and the other hand pusching the hinge-wire in, through the air-inlet? I have not tried to simulate this, but I think they are a bit far appart??!
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 09-09-2009, 03:52 PM
N941WR's Avatar
N941WR N941WR is offline
Regards, Tonny.
Oh, but those hidden hinges do spring open.
I like this idea and may use it on my new cowling. Thanks for posting.
Darn it, I can't use it with the Sam James cowl as there is no access to the wire.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-09-2009, 04:48 PM
MrNomad's Avatar
MrNomad MrNomad is offline
Default Very nice work!!
Erik:
It is obvious you are trying to do a great job. Very nice work!
I did something similar and it looks great after paint too.
After 170 hours of unbelievable flying heaven, I'm glad we designed my door to close positively and firmly else the normal vibration would have chipped the edges of the paint over time if the door was not very secure.
Nice work.
Barry
Tucson
Old 09-09-2009, 04:50 PM
Default oil door
yes it is a spring loaded hinge. not too far to hold down and pull or push the rod. thanks for the compliments dad and i are pretty proud of it.
happy building
-E-
RV7
Empennage done
Wings done
Quick Build Fuse
Old 09-09-2009, 04:53 PM
frankh's Avatar
frankh frankh is offline
Default Oh contraire!
This is MY idea...I know it must be cus its been flying for two years this way...
I have a SJ cowl and a tip up canopy..I took the brake tube and routed it such the closed canopy keeps the wire in place.I.e it goes back into the cockpit.
Open the canopy reach round and pull the wire out.
Works great.
Frank
Old 09-11-2009, 05:59 AM
db8's Avatar
db8 db8 is offline
Default Spring loaded
Did you make a small wire spring for the hinge so it would be spring loaded? Do you have a detailed picture? Thanks for sharing this idea. Dave
Dave Buntin
http://i55.tinypic.com/iny6qa.jpg RV-8, N 130YS, BOYS & TOYS
[size="1"][color="Blue"]
Old 09-11-2009, 08:49 AM
N941WR's Avatar
The spring comes with the hinge. It is a simple coil spring with two legs and slides over the hinge pin.
Bill R.
SC86 - Easley, SC
