09-08-2009, 02:31 PM
Windshield Trim Strip
On the sliding canopy, is there any pros and cons to building the windshield trim strip out of aluminum versus the fiberglass recommendation?
09-08-2009, 07:33 PM
I was referring to the "Tiara"
Thanks for your input
09-09-2009, 01:13 AM
Don't Do It - No to the Aluminum Tiara
My "Tiara" is in aluminum and I will probably redo it in fiberglass. It is too malleable. Passengers and avionics techs have a tendency to put their paws on it and bend it as they move in and out of the plane, no matter the briefing. I narrowly escaped cracking my canopy when I slammed the canopy into a bend someone put into it. The canopy is looser now so I can just slide it forward and close it with the handle, but I still check it very carefully.
I recommend fiberglass over aluminum for this reason.
Hans
09-09-2009, 06:39 AM
Originally Posted by painless
Are you referring to the "tiara", which is located in the area where the windshield and canopy meet, or the windscreen fairing located where the windscreen meets the fuselage skin?
Either area has been done in aluminum. I did my fairing in aluminum, but I could not get the tiara to sit flush to my liking with both the windscreen and the canopy with the canopy closed. It is definitely doable, just takes some finesse. The aluminum windscreen fairing was actually quite easy to do.
Regards,
Got any photos of your windscreen fairing? Thanks!
09-09-2009, 06:57 AM
I'm a sheetmetal person by trade, and thought about it.
But I like the fit of the fiberglass. I have no rubber seal, and heavy rains will never enter the cockpit. I have to blast the canopy with a hose to get a few drops inside.
L.Adamson
09-09-2009, 06:47 PM
Fiberglass is easy and looks better
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
12-11-2012, 10:26 PM
Is a trim strip necessary?
I'm preparing to attach my windshield. I've never done any fiberglass. The plans describe a fiberglass layup at the bottom of the windshield in a lot of detail,
They also barely mention a "trim strip" that hangs off the back of the windshield between 1/4 and 1/2 inch. It is shown on drawing 43' section K-K.
My question is: do I really have to make this trim strip? I can't find it mentioned in the instructions. It seems like it will be fragile, and a pain to make. Is its function really to cover the gap to keep water out?
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
12-11-2012, 10:37 PM
I made the trim strip ("tiara") out of four layers of carbon fiber. It is extremely stiff and I'm not too concerned with people grabbing onto it to get in/out of the aircraft. The rest of the fairing is fiberglass, so no aluminum-to-CF contact.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
12-12-2012, 08:47 AM
This is actually the easiest part of the windscreen fairing to make, Dave, and it keeps out drafts and noise in addition to moisture.
Ditto on this, except I used 3-4 layers of 8oz BID fiberglass sandwiched between 2 layers of carbon fiber. Although I instruct passengers not to put their weight on it, I really have no concerns about damage if they accidently do.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
