Old 09-08-2009, 05:56 AM
Steve Sampson Steve Sampson is offline
Default What sort of nut do VANS intend should be used here?
What sort of nut do VANS intende should be used here? (middle of picture)
I am talking about the nut that retains the steel pin that stops the break assembly rotating on the axle. My RV4 plans indicate a 1/4-20 (coarse thread) , but my question is should it be a nylock or steel? I am concerned that under hard braking it might get quite warm and the nylock fail. Thoughts?
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
Old 09-08-2009, 06:02 AM
Geico266's Avatar
Geico266 Geico266 is offline
My vote is for a nylock nut. It is not gonna get that hot on the end of the bolt. The brake cylinder o-rings would fail long before the nut falls off.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 09-08-2009, 07:32 AM
Mel's Avatar
Mel Mel is offline
Nylock nuts are fine here.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-08-2009, 11:56 AM
Larry/Mel. thanks for your inputs. Nylock it is.
Steve
Old 09-09-2009, 04:34 AM
plehrke's Avatar
plehrke plehrke is offline
Default AN363
Remember you can always use an AN363 self locking nut if you are concerned about elevated temps. They are good to 450 deg F.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 09-09-2009, 08:26 AM
Doug's Avatar
Doug Doug is offline
BTW these are 1/4 UNC nuts. Vans recently supplied me replacements that were nylocs for my RV-6.
The original steel s/l nuts cracked and split while threading the nuts on these stud bolts (zero torque applied). I suspect the bolts have slightly oversize thread.
Doug Gray
