Go Back   VAF Forums > Main > Reviews
  #11
Old 09-08-2009, 10:08 AM
Danny7 Danny7 is offline
Hope no one takes this seriously, dry ice and water create a lot of carbon dioxide in a hurry.
Not recommended to breathe a lot of carbon dioxide
EDIT- this is wrong, thanks for the corrections Pete and Mike
unless you fill the cabin up with carbon dioxide it won't hurt you . i don't think most aluminum planes are airtight enough for it to matter. carbon dioxide is what we inhale and exhale with every breath anyway, unless by volume it displaces o2 it doesn't do a thing to you.
you aren't thinking of carbon monoxide are you?
nothing special here...
Old 09-08-2009, 10:17 AM
PCHunt PCHunt is offline
Dry ice in the cockpit is a definite safety hazard.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 09-08-2009, 10:29 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
No, I am not thinking of CO.
The quantity of CO2 inhaled is extremely small, the amount exhaled is a bit bigger.
There are two hazards of breathing CO2, displacing Oxygen as mentioned above, and the other is that the body regulates breathing in accord to CO2 levels.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-08-2009, 10:47 AM
Louise Hose's Avatar
Originally Posted by rv7boy View Post
The web site doesn't mention the size or empty weight. Could you post that also?
The top (and bottom) are about 18 inches wide (the handles probably add an extra 1.5 inches or so) and 11 inches deep. The chest is ~14 inches high. To operate, the intake vent is raised about one inch and, of course, the blower tube extends a lot more. I don't have a good scale from this range, but the empty weight is about 7 pounds (probably +/- 1#).
One other thought, it would help a little if the canned drink(s) were frozen before placing in the cooler. With this little machine, every BTU/calorie counts!
Freezing the Moosehead? The horror!
As for adding shades, I suspect that might help on some days and at some hours. But, the sun is low enough during the evening commute that I would have to also block critical visibility to block it. And, in this part of the world, the issue usually isn't primarily direct sunlight.
Dry ice? No thank you. You would be blowing that CO2-charged air right at your face for maximum cooling efficiency. I'll stick with regular ice. I've worked in a carbonic-rich atmosphere enough to have high respect for its impact on the human body. (I could diverge into a Darwin award story here, but I'll stick with this RV-related theme.)
Old 09-08-2009, 11:04 AM
BobK BobK is offline
Default Maybe getting cooler air?
If you add salt to the ice, the melting point goes lower so the water circulation is lower and thus a cooler cool. Might not last as long tho.
Old 09-08-2009, 11:35 AM
N941WR's Avatar
N941WR N941WR is offline
And you wouldn't want that salt water leaking in your plane or pumped over the side on to the wing.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-08-2009, 01:32 PM
rjaflys rjaflys is offline
As mentioned above, the amount of water is related to the amount of cooling, but it is no problem to remove. The unit comes with a length of hose that is simply connected to the circulating pump and with the unit turned on the water is pumped out. When camping the unit can be removed from the airplane and put in the tent. With a 12 volt source like a small 110 to 12 volt power supply, you could have a mighty comfortable tent for a while. One thought is that this type cooler may be adding moisture to the interior of an aircraft, which may not be too good for avionics. Any thoughts. Bob.
Old 09-08-2009, 01:37 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Originally Posted by Louise Hose View Post
...Freezing the Moosehead? The horror! ...
I guess you can tell the strongest thing I drink is Root Beer.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 09-08-2009, 01:38 PM
Thanks Mike S and Pete Hunt for setting me straight- i was thinking co2 would affect the body more like nitrogen. in the Atmosphere CO2 is much less than 1% and how much is in you affects respiration quite a bit.
good to have guys that know what they are talking about on this forum.
Old 09-08-2009, 01:42 PM
The builder/manufacturer says that the unit is actually removing moisture from the air, making the cabin a bit drier, although I haven't figured out how that happens. I do know that I haven't had any condensation problems on the canopy or in the cabin so I have no reason to not believe him.
Since my plane lives in near 100% humidity much of the summer, I really doubt that this is an issue for us, anyway. And, in most applications, you would only have the cooler on for a relatively short time (i.e., during climb-out, descent, or out practicing TnGs).
