Old 09-05-2009, 07:31 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default RV-6a vs RV-8 speed
Yesterday on the way to Creede Colorado a RV-8 pilot and I decided to check actual speeds side by side....full throttle/best speed possible. We were at 12,500' I believe. There may have been around a 10 knot tailwind component but using GPS groundspeed I reported 176 knots and he reported 177 knots.
So considering the short run and data collection inaccuracies, we were essentially the same speed.
I think both engines are O-360 but I have 9.2:1 pistons, flow matched carbureted engine and FP prop (Catto three blade). His engine is 200 HP and with my improvements mine may approach that.
He has a 3 blade MT prop. (correction from initial erroneous Hartzell prop statement)
I have one Lightspeed ignition and he has two.
Old 09-05-2009, 10:14 AM
Kevin Horton's Avatar
He has a Hartzell prop.
What rpm did you have, and does he have an older Hartzell with 7666 blades, or one of the newer blended airfoil Hartzells?
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 09-05-2009, 11:07 AM
Default I'm Pulling for you in the RV-6A at PS
Right now it looks like there are three of you in the RV Blue Class in the Pagosa Springs, Colorado race later this month (www.sportairrace.org calendar of events), an RV-8, an RV-6 and you in the RV-6A. The other guys are fast but you can bet I'm pulling for you to show them up (sorry John and Mike). The RV-6A is a lot faster than it is given credit for.
Bob Axsom
Old 09-05-2009, 11:56 AM
Ron Lee's Avatar
Default Excellent critical info Kevin
I do not recall my RPM but will do it again in the near future and report it. I will ask about his (RV-8) blades. (it is a 3 blade MT prop...corrected first post).
Bob, if John Huft is running he will be on the ground eating lunch before I finish.
Old 09-05-2009, 12:44 PM
Default Beat Your Previous Race Speed
John Huft is in with his Super Fast RV-8 and Mike Thompson is no slouch in his RV-6 either. You can shoot for beating your Memphis speed. When I run the course I am so engrossed in flying as straight and level and fast as I can making all of the turns correctly with required approach calls and my senses peaked with the exhilaration of the moment that how I finish is almost (not quite) an afterthought. I really like to finish above 210 mph if I can but above 200 mph is OK. Before all the mods those standards were 190 and 180 mph respectively. Enjoy the race and do the RV-6As proud.
Bob Axsom
Old 09-05-2009, 03:04 PM
Ask him for the full prop model number, if he can find it. The older MTs were known to be quite slow. Recently, they came out with a new blade (model number ends in "-59b"), and some folks claim it is quite a bit faster than the older one.
Kevin Horton
RV-8
Moses Lake, WA, USA
