Old 09-03-2009, 07:07 PM
rickjfly rickjfly is offline
Default navaid problem
I purchased an RV-7A with a Navaid autopilot installed. From day one it will not track either a heading or a GPS course. The wing leveler function works fine. I have no manuals for this unit. Any ideas?
Old 09-03-2009, 07:18 PM
rocketbob's Avatar
Not enough info to even begin to diagnose. Manual is here: ftp://ftp.porcine.com/SmartCoupler/NavaidOCR.pdf
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 09-03-2009, 07:21 PM
N131RV N131RV is offline
Default Suggestion
The manual is still available online from the porcine website.
To track a gps the navaid must be equipped with a porcine gps smart coupler.
There are a couple of different models. Some are built into the control head and some are separate.
Does the autopilot have a little toggle panel? It would be separate from the control head. There might also be an old style one (three buttons).
In any case, a navaid will track a vor or if it has the porcine coupler, it will track a gps signal. The gps must be set to output NMEA and the proper connection must be made from the gps to the control head.
In addition, the coupler must have it's mode set as well. On mine, holding the toggle to the left for a few seconds flashes the mode led a few times, then it turns solid green, meaning it has a gps lock. It will not turn green until the gps has a position lock and the data is being sent from the gps to the coupler.
You can get a scanned copy of the manual from ftp://ftp.porcine.com/SmartCoupler/NavaidOCR.pdf
Hope this helps.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 09-04-2009, 04:41 AM
mrreddick mrreddick is offline
Super Moderator
Location: Hangar/home at Hicks Airfield (T67), Fort Worth, TX
Like already said, not much info on your configuration. I have it linked to a panel mount Garmin 250 (no smart coupler required) and mine tracks fairly well, with constant adjustments during fuel burn.
You can get a plug n play replacement from Trio or Trutrak, the Trio has more features for the bucks (around $1,000).
You won't have any problems tracking a route with either one of those units.
Mike Reddick
VAF#153
Pilots N Paws Pilot
RV6A N167CW 1,900 HRS
Ft Worth, TX (T67)
Old 09-04-2009, 07:15 AM
Sam Buchanan's Avatar
been here awhile
Links to the manual have been posted. I suspect there is a wiring issue at the Navaid connector. Depending on what you are using to send data to the device, you may need either a couple of jumpers at the connector to get a signal to the Navaid or a switch to select either CDI or NMEA data. Study the Navaid wiring diagram carefully and confirm all necessary connections are present.
I think TruTrak has discontinued the Navaid-compatible version of their Digi-Trak.
Sam Buchanan
RV-6
Fokker D.VII replica
