Old 09-02-2009, 08:54 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Default Carb Attach Hardware?
My engine has 5/16-18 carb studs. The parts manual shows the attach hardware to be plain flat washers, plain nuts, and palnuts. What's a palnut? Should I use something else instead?
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 09-03-2009, 01:46 AM
dhammer's Avatar
dhammer dhammer is offline
Default Palnut
Standard hardware used as a jam nut to lock down a plain nut. Nothing wrong with using them for this application.
Decent picture at -
http://shop.comdir.co.uk/Products.as...rWebTemplate=C
Old 09-03-2009, 04:50 AM
mahlon_r mahlon_r is offline
The current hardware is a nut, flat washer and a star washer. Palnuts have not been used in years on Lycoming engines.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 09-03-2009, 06:19 AM
flickroll's Avatar
flickroll flickroll is offline
In lieu of a star lock washer, if the stud is long enough (as it is on my -8), a MS35338 split helical lock washer can also be used. The star washers must be discarded and a new one used if the nut is ever removed. The split helical washers can be used again. YMMV
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 09-03-2009, 09:38 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
My engine came with an363-518 nuts holding the FI servo.
They are hard to find, I found out.
GAHCO shows them in their catalog.
Star washer setup ala Mahlon's post is easy to do, and works.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-04-2009, 07:25 AM
Lionclaw's Avatar
I've got a big bag of star washers from spruce, so I'll probably go that route. Thanks for the help!
