Old 09-02-2009, 11:10 AM
jmainjet@msn.com jmainjet@msn.com is offline
Exclamation Rv-7 spin test with pics?
How about the recovery from a spin with the original supplied rudder?
Has anyone done it besides Vans? If so, did you record the event?
I'd like to know the details before I Man up to doing the test. Any comments would be appreciated. Same goes with your own horror stories.
Thx
John
Old 09-02-2009, 01:27 PM
kevinh's Avatar
kevinh kevinh is offline
I practice spins in my 7A every few weeks (with the 'new' rudder). It spins fast - try searching the forums. I think someone posted a good pilots eye view video some time ago.
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
Old 09-02-2009, 01:28 PM
kevinh's Avatar
found it: http://www.vansairforce.com/communit...ght=spin+video
Old 09-02-2009, 04:13 PM
Andy Hill's Avatar
Andy Hill Andy Hill is offline
I've tested a few RVs, including 7 and 6As, for spinning, in the UK. Never any doubt about the recovery - indeed, as with others, suspect "letting go" would see a recovery. They do not want to spin, and only get going after Turn 2 or so... but then the SBSs do get going Somewhat quicker than the 8...
Andy
Old 09-03-2009, 09:00 AM
Default RV-7 spins
Thank you. As for my airplane I will approach the spin regime with alot of caution. I have taught spin recovery in Cessna and Piper aircraft and as a younger man. I never thought it to be problematic. I have with age grown to respect the open forums and shared insight while building the RV-7. Now its time to go to the next level. However, "Caution" is the operative word.
Did you spin the -7 with the original rudder?
Old 09-03-2009, 09:22 AM
jtrusso jtrusso is offline
Thx
John
Here is a video of an RV6 recovering from a spin during a botched loop:
http://www.youtube.com/watch?v=cfc0o...om=PL&index=20
-John
Flying a Glasair I FT
Planning to build an RV...someday
Old 09-03-2009, 09:37 AM
Maxrate Maxrate is offline
Currently building a 7 and want to get it certified for spins eventually. What do you mean by "new rudder".
Thx,
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 09-03-2009, 09:44 AM
kevinh's Avatar
Thx,
The original rudder was smaller - they switched to the larger counterweighted (current) rudder a few years ago. I built my plane from 2003-2005 and I had the new rudder - someone else can probably post a better way to recognize the new rudder.
I've only spun my RV (with the new rudder) - other than spinning pretty fast it was fine. If you have the original rudder I'd definitely do more research before spinning.
Old 09-03-2009, 09:54 AM
Mel's Avatar
Mel Mel is offline
Thx,
The original rudder supplied with the -7 was the same as the RV-8. It was later changed to the RV-9 rudder which is taller and has a larger counterbalance.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-03-2009, 05:43 PM
frankh's Avatar
frankh frankh is offline
Default RV7 spin
With opposite aileron to make it mad at me..
The start of this video shows a 5.5 turn spin.
http://www.youtube.com/watch?v=TQIZQ2yti1Y
Frank
