Old 08-31-2009, 07:49 PM
Tbone's Avatar
Tbone Tbone is offline
Default Plexiglass Countersink?
After reading several post on the correct, or let me say, different ways to countersink plexi is there a problem in not using any countersunk screws at all on the canopy? It seems to me that there are many different screws that could be polished "stainless" that would not give a tall profile and still look good. Are the countersinks in the glass to keep the canopy "centered" on the frame? I also thought I saw a RV at OSH and it had tinnerman washers under the screw but were cut back to the screw edge. Not sure what for. What are some of the ingenious ideas of the RV community on this issue?
___________
Terry
RV7
XP IO360
Old 09-01-2009, 04:32 PM
Tbone's Avatar
Any takers?
___________
Terry
RV7
XP IO360
Old 09-01-2009, 05:22 PM
roee roee is offline
You could probably use non-countersunk screws on the canopy if you really want to. But the obvious penalty would be added drag from the protruding screw heads. Seems like a waste.
My advice: Don't become disproportionately frightened of this issue just because some builders have experienced problems. Remember that most builders have gotten through this with no problems, and that clear lessons can be learned from the problems that have occurred. As for the "right" technique, or "different" techniques, I wouldn't take anyone's word for it as gospel. Take some scrap plexi and experiment with it yourself until you've got a technique that you're satisfied with.
Tinnerman washers are a good idea to use under the screws where there is no aluminum skin to spread the load on the flat surface of the plexi, i.e. along the roll bar. I'm not sure what you mean by "cut back to the screw edge". The wide flange of the tinnerman washer is what makes it useful, so I don't know why someone would cut that off, if that is indeed what you're describing.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 09-01-2009, 06:31 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default cutting, drilling, countersinking... oh my!
make sure that you are using the correct sized pilot hole for the countersink and it should make a very clean and smooth cut without any chatter. when i used a thin uni-bit to open up pilot holes to 5/32 i ran a dulled #19 bit from the back side to match my piloted countersink bit and the countersinking was a non issue.
after completing the cutting, drilling, and countersinking on my tip-up i had the worst success with the so called 'plexiglass bits'... much better results using a dulled bit... i dulled several designated bits by running them against a deburring wheel per the recommendations on the EAA site (one of the online instructional videos).
in any event i would not want to work on the canopy in the winter...
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 09-01-2009, 07:49 PM
mikehoover's Avatar
mikehoover mikehoover is offline
I used a regular dull bit with no problem. On countersunk holes I used the microstop countersink and found that you need to use low rpm to prevent having too much heat. And it cut quicker and smoother at low rpm. I was working in very hot conditions - 90-100 degrees in the hangar.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 09-02-2009, 05:19 AM
Tbone's Avatar
I have no problem with countersinking plexi, I was just curious if others have entertained the idea of not countersinking and using different screws. I wouldn't think the drag penalty would be an issue.
___________
Terry
RV7
XP IO360
