Old 08-31-2009, 07:08 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Default Manifold Pressure test
What's an easy way to test my manifold pressure gauge to see if it's bad or if I have a leak in the tubing.
At rest it seems to read about right, however, when I pull to idle on downwind, about 2300MSL here I my home field, the MP is going to about 20 inches. I know it should be lower than that but don't know if its an indicator or tubing leak.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 08-31-2009, 08:45 PM
AlexPeterson's Avatar
Jerry, since you aren't at too high an altitude, you can verify your (approx) sea level MAP gauge reading by dialing your altimeter until it reads 0 msl. The resulting barometer (kollsman) reading should match your MAP gauge with the engine not running. But, it sounds like you believe that is ok.
If you disconnect the tube at the engine, you should be able to suck a reasonable vacuum, cork it with your tongue and see how quickly it leaks, if at all. Someone else could be in the cockpit monitoring MAP.
Your flight idle MAP should be something in the neighborhood of 6 to 10"?
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 09-01-2009, 10:48 AM
Noah's Avatar
Noah Noah is offline
Would be easy to build a water manometer with a piece of transparent tygon or nylon tubing, you'd be able to make just about any pressure you wanted with a long enough piece of tube. Juts make the tube into a U shape and the difference in height from one side to the other is the vacuum pressure (in inches of water). You would need to convert this to inches of mercury to check your gauge. Search the archives on manometer or U-tube manometer and you will find detailed descriptions on how to set this up.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
