Old 08-31-2009, 06:02 AM
jtrollin jtrollin is offline
Default Are auto pilot servos specific to the autopilot?
So thinking about getting the roll servo and mounting it in my wing before skinning it up and have not yet decided which autopilot to use, can I make the servo decision now and just control the servo with what ever autopilot I choose down the road (ie buy a Dynon AP Servo and control it with a trutrak autopilot?).
Also looking at the RV-10 plans and how the autopilot mounts to the brackets on the main spar it looks like there is no way to access the leading edge side of those brackets once the leading edge is riveted to the main spar. If I mount my autopilot servo there will there be anyway to remove and replace the servo once the leading edge is riveted on the to spar? It seems odd that there is no access to the back side of those bolts once the leading edge is on.
thanks
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Old 08-31-2009, 06:31 AM
rleffler's Avatar
rleffler rleffler is offline
No, servos for the most part aren't interchangeable between the vendors. It would also end up giving you a nightmare for support, should support be needed.
thanks
There are nutplates for those screws, so access to the other side isn't an issue. I replaced the van's supplied mounting bracket for the trutrack on after my wings were assmbled and leading edges attached.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 08-31-2009, 07:45 AM
Default You're right.. I wasn't thinking
There is a nutplate there... for some reason I thought it was a washer and nut on the other side.
thanks.
John - Leesburg VA
RV-10
Phase 1 Complete
798HJ Reserved
