Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 08-30-2009, 08:00 PM
Walt's Avatar
Walt Walt is offline
Default 696 Questions
I've seen a few folks talk about using the "rubber band" feature for the course line but I cannot find any info on this or have been able to figure out how to do it so need some help with this one?
Second, on the 496 I had the course line setup so it would always show a line to the destination (always on track) and the line "behind" you would not be there, I can't seem to find this same funtion on the 696, is it possible?
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-30-2009, 08:48 PM
Ironflight's Avatar
VAF Moderator / Line Boy
The "Rubber Band" feature is found in Flight Plan mode - hit the Flight Plan button, then "Use Map" - the cursor will become active, and when you slide it over the existing course line, the course line will change color. You can then grab it and pull it to a new intermediate way point.
It would be nice if you could do this on the main map page, but it isn't implemented that way.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-30-2009, 08:50 PM
pmccoy's Avatar
pmccoy pmccoy is offline
Default Rubber Band
Walt-
I don't have my 696 in front of me... so this is from memory. When you are in flight plan mode you have a selection for map. This allows you to click on the map and add to the flight plan. I think this is the feature people are talking about. Give it a try.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
