Old 08-30-2009, 02:00 PM
prkaye prkaye is offline
Default current caclulation
I'm working out my avionics current load. The GTX327 says maximum power input of 20Watts. So my naive calculation of 20W/12V < 2Amps means this this device will never draw more than 2 amps. Have I done this correctly?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-30-2009, 02:05 PM
RV6_flyer's Avatar
P = IV (P = Power is Watts, I = current in Amps, V = Volts)
20 W / 12 v = 1.6666 Amps
A two (2) amp CB or fuse will work. Make sure that the wire is the correct size (or larger) for the fuse or CB.
Your calculations are correct.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-30-2009, 02:12 PM
sjjonesnz sjjonesnz is offline
FYI, the GTX327 installation manual calls for a 3A breaker...
Cheers
Steve
Auckland, New Zealand
Flying RV-7QB/ZK-NVS/Aerosport 0320/Dual AF3500s/PMA8000B/GNS430W/SL30/GTX327/TT ADIP II
Old 08-30-2009, 08:15 PM
Greg Arehart's Avatar
And remember that the breaker is not designed to protect the avionics, but to protect the wiring.
greg
Greg Arehart
N 7965A
Old 08-31-2009, 06:47 AM
Crossbow Crossbow is offline
Well, since you are asking for opinions, I can think of three additional things to consider:
One, as was pointed out, the 327 manual specifies a 3A breaker, so you might want to stick with that.
Second, while this might not be a factor since the wiring run will be relatively short between the 327 and the power source. However, I think it would be good practice to account for the voltage drop in the wiring as well.
Third, as was also pointed out, the fuse/breaker is there to protect the wiring, not the device.
I hope this helps!
