Old 08-30-2009, 10:06 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Stuck in Kelso, WA
Cliff Gerber with a -9a is stuck in Kelso, WA with a flat main and needs a tube.
Any local help much appreciated. 360 425 4600 for motel or 360 414 4333FBO
Cel phone dead, of course...
Jerry
Old 08-30-2009, 04:38 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
I just saw this and called the FBO and they said Cliff got it fixed and was just now leaving.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 08-30-2009, 05:07 PM
frankh's Avatar
frankh frankh is offline
Default Sweet
and just for reference I carry a spare tube on long coss countries cus you never know. I also carry tools..the only thing I would need is some kind of block for the axle and another fellow to lift the wing (crouch down under the outer wing and stand up a little) and a compressed air source.
Worth carrying the spare tube in my mind.
Frank 7a
Old 08-30-2009, 05:25 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
I carry two tires and tubes plus a small foot operated air pump.
Old 08-30-2009, 05:28 PM
TSwezey TSwezey is offline
Frank 7a
I carry a cheap light weight auto pump with me that plugs into a cigarette outlet. I used it the second day of Osh. I had to save another RV-10 stuck on a taxi way with a flat tire.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 08-30-2009, 06:39 PM
frankh's Avatar
Default got a source for a compressor?
The ones I have seen are pretty large..I'd be interested in one a few inches square.
Frank
Old 08-30-2009, 08:53 PM
G-force's Avatar
G-force G-force is offline
Check out ones for motorcyclist, small and lightweight.
http://www.aerostich.com/prevent-or-repair/tire-repair
Mike Sumner
Castaic, Ca
Old 08-31-2009, 11:34 AM
frankh's Avatar
Default Anyone tried these?
From good ol Harbor freight?
http://www.harborfreight.com/cpi/cta...temnumber=4077
or
http://www.harborfreight.com/cpi/cta...emnumber=43520
Frank
