Old 08-28-2009, 01:53 PM
prkaye prkaye is offline
Default teflon tape?
For the SafeAir kit attachment to the aluminum tube on the Dynon pitot probe, for the threads on the blue AN fitting that screw into the brass hydraulic fitting, should I use Teflon tape? These ones did not come from SafeAir with teflon tape pre-applied, as other fittings in the kit did.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-28-2009, 02:02 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Teflon tape is fine for air fittings. However, do be careful to not get any tape in the system. However, teflon tape is a N0-NO on all fluid fittings on aircraft as far as I know. If some sort of thread sealant is necessary, teflon paste or the like can be used.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
