Old 12-25-2005, 02:07 PM
GaryK's Avatar
GaryK GaryK is offline
Default Countersunk washers
Does anyone have a source for SS 100 degree countersunk washers for a #4
screw? The usual vendors only go down to a #6 screw.
Thanks and have a safe holiday,
Gary Kremers
N715AB
Old 12-25-2005, 02:14 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default McMaster.com
If this is what you are looking for:
then try part number 98466A005 at McMaster.com. It does not say that it is 100 degree, but with a screw that size, it really should not make much difference.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-25-2005, 06:49 PM
w1curtis's Avatar
w1curtis w1curtis is offline
I think countersink washers and I think of this:
I see Spruce only has it to a #6 also.
William Curtis
SB RV-10 40237, Status, Panel, Engine, Paint, Me, NE RV-10 Page, Cessna 177RG, AF Missions
?Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.? - Dr. Suess
Old 12-25-2005, 06:55 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default #4 Washers
Check with Cleveland tool. They make a wing tip kit with the 4-40 stuff. If you are going to use them for the tips definitely reconsider. I had mine done with #4's and CS washers and I didn't like it. I took a couple of hours and drilled all the #4 nutplates out and used #6 hardware with Tinnerman washers. Looks much better and much easier to use.
Darwin N. Barrie
Chandler AZ
RV7 flying
Old 12-25-2005, 07:06 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default #4 is small
Just curious what are you using #4's on, those a small little suckers. G
Old 12-25-2005, 07:38 PM
tacchi88 tacchi88 is offline
Default Countersunk wahsers
I bought mine at Freeman Aviation, Griffin, GA. Also B&B aircraft supplies, in Ks.
T88
Old 12-25-2005, 08:42 PM
GaryK's Avatar
Default #4 is small
I used #4 on the wing tips, they came out great. After 100 hours I've decided to install a second comm antenna under the fuselage. The Bob Archer wingtip comm is marginal, 10 to 15 miles but that's about it. Instead of leaving the antenna and RG400 in the wing I started to remove the wing tip. The paint around the screw heads started to crack slightly. Before removing any more I just wanted to see if #4 100 degree countersunk washer were available. It's not a huge big deal just trying to locate them if nessesary.
McMaster doesn't have the type I'm looking for.
Gary
Old 12-25-2005, 08:51 PM
GaryK's Avatar
Default #4 screws
I forgot to mention the #4 screws I'm using have a torx head. Much easier to install. In fact all the inspection plates, fairings, wing root, et. have Torx heads.
Gary
Old 12-26-2005, 06:13 AM
rv8ch's Avatar
Default Torx
Torx screws are great. I bought a bunch from Micro Fasteners in NJ, and use them everywhere I can. So much nicer than phillips.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 12-26-2005, 07:51 PM
markscogg markscogg is offline
Default #4 countersink washers
Aircraft Spruce has #4 countersink washers if you look hard enough. They are $1.15 EACH!!!!
Mark
Flying -6
