Old 08-26-2009, 05:49 PM
TCONROY's Avatar
TCONROY TCONROY is offline
Default Extra Dimple...help
Well today I made my first big mistake. It could be an $85 mistake that took about 2 seconds to make. I was on a roll dimpling my VS skin and didn't quite have the skin set on the bottom male dimple when I whacked it.
The result was several choice words I wouldn't say in front of my mother and this extra hole. Is there anything I can do to save this skin? To give it some context, the hole connects to the front spar and is about 4 down from the top of the VS.
________
Trevor Conroy CFII, MEI
Airbus Pilot
N781TD
RV-7
First Flight - April 12, 2015
Construction Log
Old 08-26-2009, 06:06 PM
Geico266's Avatar
Geico266 Geico266 is offline
I'd buy a new one and keep the material for other projects down the road. JMHO.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 08-26-2009, 06:14 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Make it look like it's supposed to be there...
...drill two new holes between the "oops" hole and dimple and rivet as per the others. It will then be at least as strong as the plans standard. Either leave the "oops" hole "as is" or use a unibit to open it out enough to a clean hole that removes the "evidence" and any future stress raisers. It will be backed up by the the rib flange and or covered by filler/paint.
Build on McDuff!
Jim Sharkey
Old 08-26-2009, 08:04 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Will any builder who has completed their RV and hasn't made at least one "figure eight" or "double hole" please raise their hand? I see very few hands up.....
Flatten the dimple and put a hole on either side along the rib as Jim said, and it will be just fine as an airplane. If you want perfection of course, you can order a new skin, but it is not necessary.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-26-2009, 08:24 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
One boo boo here...another there.....and another....and another. Before you know it you'll be naming the plane 'Boo-Boo'.
Of course you want perfection.....buy a new skin.
Paul
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
Old 08-26-2009, 08:53 PM
danielhv's Avatar
danielhv danielhv is offline
Been there done that! Trust me.. this early in the game, do what the other guys have said and flatten it out, and make 2 holes on either side. Later down the road, you can fill it in and you will never know it was there. If you nit-pick this early in the game a replace the skin because of one oops... its going to be an EXPENSIVE build by the time you fly. Just move on, there are more to come.
Old 08-26-2009, 09:22 PM
TCONROY's Avatar
Thanks a lot for all the comments. I'll attempt to flatten the dimple and drill holes on either side. Though dimple-flattening is something I have not explored yet either. I'll have to make use of that handy Search feature. To everyone on VAF, this is the best builder reference out there! I've done countless hours of research on this site before buying my tail kit last week. You guys are awesome!
________
Airbus Pilot
N781TD
RV-7
Construction Log
Old 08-26-2009, 10:04 PM
Paul Thomas Paul Thomas is offline
I made stupid mistakes early on and replaced parts. I've learned from my experience but, at this point, I'd just fix it as others suggested.
Old 08-26-2009, 10:14 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default De-Dimpling
I have had success with using a pair of flat rivet sets in my
DRDT, they will probably work in a "C" frame also.
Try on scrap first.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
