Old 08-25-2009, 08:18 AM
jeiting's Avatar
jeiting jeiting is offline
Default Preview Plans
I'm heavily considering building an RV-7A. For logistic reasons, I will not be able to start for 12 months or so. I thought I would use this extra year to prepare as much as possible. My question:
Would it be a bad idea to order the preview plans this far ahead?
My concern is that the design could change in 12 months and my preview plans would not be accurate. Should I just go ahead and order them anyway?
Old 08-25-2009, 08:23 AM
Phil's Avatar
Phil Phil is offline
Order them..
The plane has been around forever and probably won't change. But if it does, you can find the chanes here.
http://www.vansaircraft.com/public/notices.htm
Old 08-25-2009, 08:26 AM
MNForrest MNForrest is offline
I found a "used" but current set of preview plans for my RV-9 (six months before I purchased the tail kit) on VAF for $25 shipped. Post an ad in the classifieds.
www.flyexperimental.net
Old 08-25-2009, 08:48 AM
BoilermakerRV's Avatar
BoilermakerRV BoilermakerRV is offline
Default Latest Plans
jeiting, Welcome to the forum.
According to Van's site, the preview plans are only updated once or twice a year anyway, so you would most likely have the "latest" version of the preview plans.
Also, don't forget that with each kit, comes the latest, greatest and full size drawings for that kit. That way you always have the most current info.
I approached the preview plans as an introduction to how the drawings and manual are laid out and a sneak peak of the design. I will be spending quality time with the full size drawings before starting any work.
Good Luck!
Michael
Danville, IN
RV-7A Canopy/Finishing
N317PU Reserved
2020 Dues paid (February 2020)
Old 08-25-2009, 08:52 AM
K?hler's Avatar
K?hler K?hler is offline
My -9 tail kit included the current E-size dwgs and portion of the binder plans/instructions, for that kit. I assume this is typical, i.e. you will get the current info with each kit you buy. So really zero risk in buying preview plans ahead. Plus the -7 is a mature design as previously noted.
-Karl-
9 Emp.
"cart-before-horse" plan: (build now / learn to fly later)
Old 08-25-2009, 10:04 AM
llavalle's Avatar
llavalle llavalle is offline
This the typical way for Van's : each kit will come with its full size plan and the corresponding section of the build manual. I bought my preview plans in 2004 and started less than a year ago. No problems there.
Philippe Marseille
RV-9A Kit Emp done, wings @50% - SOLD
RV-12iS@Empennage
Construction Web Cam
Old 08-25-2009, 10:08 AM
jeiting's Avatar
Ok, sounds like I'll be ordering them today.
Thanks everyone.
Old 08-25-2009, 10:12 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Yes, yes, yes. Use the time to review all the drawings and instructions. You will have a much better picture of how things go together and what is coming up. It will help you avoid mistakes. You can also make notes from tips posted here that may not seem important now.
Mike W
Venice, FL
N164WM
