Old 08-23-2009, 07:23 PM
avee8tor13 avee8tor13 is offline
Default How does one cut access panel in fuel tank?
What is the best way to cut an access panel in a fuel tank?
My concern is metal shavings.
Old 08-23-2009, 07:59 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Maybe someone will come up with a better way to deal with shavings.
But for a rectangular hole, I'd use a cutting wheel in a die-grinder. You can even drill smaller holes at the corners, and file a larger radius.
For round holes, I'd go to Home Depot and get a Malco sheetmetal router that fits in a drill. They are less than $50, and have a range of adjustments for hole sizes. It uses a special drill bit on an adjustable arm to drill the hole, such as 6" diameter. This will create a perfectly round hole. I used one of these on numerous parts of my aircraft.
L.Adamson --- RV6A
Old 08-23-2009, 08:06 PM
One way is to mount the tank in a cradle, then cut an access panel in the rear baffle using a fly cutter in your drill press.
What part of the tank do you need to access, and is the tank on the airplane?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-24-2009, 04:26 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Basic Shop Practices
Your gonna get shavings. That's not a problem. If the tank had fuel in it, I'd be far more concerned with explosive fumes ruining your day. To replace a rusted filler flange, I had to cut in an access hole in a Piper Cherokee fuel tank which is similar in construction to RV fuel tanks. The first thing I did was flush the tank out with water. I then refilled the tank with water again (to displace any remaining fumes) before cutting the opening into it. Using a fiber cut off disc to rough cut the opening, I then followed up with a common 1" rotary file fitted to the same die grinder to remove the remaining material up to the (previously etched) scribe line.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 08-26-2009, 05:46 PM
Default thank you gentlemen
I am working on a fuel tank that has not been installed or has had fuel in it. I am going to cut a hole in the back on the tank (RV-10) with the tank on two saw horses thus the shavings would fall away from the tank.
