View Poll Results: improvements for Vans models
Prepunch option for -3 or -4 10 19.23%
factory fastback option for -3 or -4 or -8 8 15.38%
different wing for heavier aerobatics on certain models 1 1.92%
modular fuel increase option for all models 20 38.46%
beefed up engineering for more hp on certain models 2 3.85%
making a regular quick build option for the entire -3 or -4 6 11.54%
full CAD re-do of RV-3 kit to include better instructions and prepunching 5 9.62%
Voters: 52. You may not vote on this poll
Old 08-23-2009, 05:00 PM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Default improvements to work on
Hello Folks.... since we all know about the economy and it's wandering.. I though I'd see what people want as far as improvements to the Vans Line that would be less than designing a whole new airplane... feel free to fill out the poll and put out some good info. Not looking for inputs of x-15 through biplane amphib Just specific low to medium cost options.... "ALSO--- here this... this is not in any way shape or form meant to have somebody get upset or think that we are trying to tell them how to do their job.... so no sourpuss responses please"
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
Old 08-23-2009, 05:18 PM
Danny7 Danny7 is offline
I'm not an engineer, but it seems like it would be an easier option to ask one of the Van's engineers to figure out how to add some fuel to a wing and what it would do to it, and in the same manner increasing strength on things to enable higher power engines to be put in them.
nothing special here...
Old 08-23-2009, 05:40 PM
rvbuilder2002's Avatar
It's always good for a company to have feedback from within the industry it serves, and a poll such as this could do that, but thought I would point out, quite a number of the projects that you propose would more likely kill a company that help it. Particularly when the economy is slowed a bit.
An example would be the first poll choice...All pre-punched RV-3 or 4.
This type of engineering is not just a fill in job to stay busy. To be able to build tooling for making all of the parts and have them match up exactly like all of the other P.P. kits. To do this with teh 3 or 4 would basically require the same engineering effort as any of the new kits. The reason for this is there are no computer models. It is all just the original drawings done by hand by Van. I doubt that there would be enough sales volume of this type of a kit upgrade to come even close to getting back the investment dollars. I believe that would be the case for the majority of the projects proposed in this poll.
Scott McDaniels
Hubbard, Oregon
Old 08-23-2009, 06:08 PM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Mach Hole / Prepunch QB
5 or 6 years ago I ask Van,, A lot of us would like a 3. Any thought of making a mach hole kit? He said sure, just "order 900 of them"
Most US Pilots are too fat to get in a 3 or 4. The sales show this.
The 8 is a wonderful airplane. Glad I have mine. Now I am just ready to fly the planes I have and help others along with theirs.
I voted for QB, prepunched 3 & 4 but it is not likely.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 08-23-2009, 06:33 PM
newtech's Avatar
newtech newtech is offline
Default Light weight firewall forward option for RV-7
The RV-7A was designed to accommodate an angle valve 200 HP 360 engine and constant speed propeller. It is hard to get full access to the 100 lb. potential of the baggage area with a parallel valve O-360 and Catto composite prop. As strongly as Van stresses - "build it simple and light" I can't imagine he really wants us putting thirty pound crush plates on our props just so we can get the plane to balance in the sweet zone necessary to be able to carry the full 100 lb baggage limit. Sure would be nice to have a light weight firewall forward option.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 08-23-2009, 07:48 PM
If you look in the Van's Aircraft Accessories catalog you will not find any fixed pitch wood or composite propellers offered.
Van's sells what they recommend be used.
It is true that many years ago Van advocated the use of light wood props on the 3, 4, and 6. Builders wanted to use heavier props so the later designs were engineered to account for that. If you choose to install a propeller on those models that is not what Van's recommends, there is a good chance you will an impact on baggage area payload capability. The stress is build light where able. Instrument panel, interior appointments, etc.
Scott McDaniels
Hubbard, Oregon
Old 08-23-2009, 07:49 PM
jthocker's Avatar
jthocker jthocker is offline
For cryin' out loud!
There is an RV3, an RV4, RV7, RV8, RV9, RV10, a generous assortment of A models. Pick one! Build it to plans, fly it, then if you can find something better, buy it or build it!
Leave Van's alone, they know what they're doing!
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 08-25-2009, 02:17 AM
Kiwi Kiwi is offline
Default High wing.
I'm with Jon, but it's a pitty they can't come up with a high wing model........
Old 08-25-2009, 05:55 AM
noelf noelf is offline
Default I seem to recall...
...in a long past issue of the RVator...Van (or Ken, or xxx) describing the market requirements of the "next" aircraft they would pursue...the one that is now known as the RV-10. I will look in my back issues and see what the date / issue number is...
