Old 08-22-2009, 03:17 PM
wings444 wings444 is offline
Default Red fuel selector handle for RV-8
Saw red fuel selector handle for the Vans fuel selector and feel in love.Went back on internet to purchase and could't find the site Does anyone know how to reach the vendor ?
Old 08-22-2009, 03:21 PM
islandmonkey's Avatar
islandmonkey islandmonkey is offline
Default Andair
The only company I know selling fuel selectors with red handles is Andair:
http://www.andair.co.uk/system/index.html
Anthony Johnston
Brit working in Zurich, Switzerland.
1500 hour pilot and ex instructor and examiner.
RV-4 s/n 4572 Emp Kit.
RV-3B s/n 11460 Emp Kit. (In storage).
Anthony's RV-4
Old 08-22-2009, 03:22 PM
hydroguy2's Avatar
like these? Vans link
Old 08-22-2009, 06:46 PM
gator gator is offline
I think Classic Aero Interiors also sells one
Old 08-22-2009, 09:22 PM
SMO's Avatar
SMO SMO is offline
Default Others
Cleaveland and Stein both sell this fuel selector lever
http://www.steinair.com/accessories.htm
http://www.cleavelandtoolstore.com/p...p?number=RVFS1
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 08-24-2009, 04:48 AM
Rick6a's Avatar
Rick6a Rick6a is offline
As an additional data point for your consideration, I matched that upgraged red fuel knob to Bob Ester's fuel selector plate: http://www.rvengraving.com/fuel_selector.htm
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 08-24-2009, 05:36 AM
Jamie's Avatar
Jamie Jamie is offline
I am a big fan of Cleveland Tools, but I had their red fuel valve and did not like it. I didn't like it because of the way it works...it has a round hole for mounting and it has an allen screw that presses against the flat spot on the valve "shaft". Yes I had the allen screw installed with loctite and it never failed on me and it was still tight when I removed it, but it made me nervous every time I turned it.
I then installed the Van's lever (part #: FUEL VALVE LEVER) and it has the hole machined in the same shape as the shaft so there's really nothing to fail. The Van's lever is also a bit larger which I like (it's also more ergonomic).
I simply don't like adding one more failure mode (a screw backing out) to my fuel system.
Old 08-24-2009, 06:32 AM
N8RV's Avatar
N8RV N8RV is offline
Originally Posted by Jamie View Post
...I simply don't like adding one more failure mode (a screw backing out) to my fuel system.
Aw, c'mon ... you're just being a wuss. If the handle comes off, just pop a vice-grip on there and you'll be OK. It's been done before ...
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 08-24-2009, 12:02 PM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
The vice-grip thing was done very successfully by John Denver in a LongEZ!
Why is everyone so excited about dressing up the fuel valve. Why not go to the Andair fuel valve and have a great valve and a great looking red handle? The important thing is the valve, not the handle!
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 08-26-2009, 10:56 AM
Jamie's Avatar
Some folks (like me) installed the fuel valve that came with the kit but were unhappy with the look of the handle after flying for a little while. It's certainly easier to swap out a handle than an entire fuel valve. In short, it's an easy aesthetic upgrade...so why not?
Another reason people like the red handle is the pointer. With the supplied fuel valve the handle points at the selected tank. It's completely obvious which tank is selected, even to pilot who may be unfamiliar with the airplane.
