Doug,
The stock ports are simply rivets, so you should be able to pass a drill the same size as the center pull of the rivet (not sure if the proper terminology is the mandrel). Ultimately, I don't think the diameter really matters much as long as there is free air getting into the plastic tube that goes to the instrument panel.
greg
Greg Arehart
N 7965A
