Old 08-20-2009, 02:42 PM
Luebben Luebben is offline
Default High compression pistons
Let me know if I am thinking wrong. If I fly at 8000 feet or higher most of the time, wouldn't higher compression pistons benefit me? The atmosphere is thinner, the engine produces less power because of that. Could I not regain some of the lost power by increasing my compression from 8.5 to 1 to 9.5 to 1? I have read the compression threads but I did not find information about high compression and high altitude flying. Thanks in advance!!!!!
Old 08-20-2009, 03:00 PM
rbibb's Avatar
rbibb rbibb is offline
Well since higher compression pistons allow the engine to produce more HP at sea level they allow a proportionately more HP to be produced at altitude.
You start with more you end up with more.
Of course there is no free lunch - you will burn more fuel as well.
But, all in all, more HP is better than less.
Ah Physics - the laws that simply must be obeyed.
Old 08-20-2009, 05:26 PM
douglassmt douglassmt is offline
Default Physics humor
Indeed, physical laws. My favorite from the bathroom wall in the physics building in college:
186,000 miles/second (the speed of light)
It's not just a good idea, it's the law!
Bryan Douglass
=VAF= 2020 dues paid
RV-10 N242BD
Old 08-20-2009, 05:29 PM
Toobuilder's Avatar
Originally Posted by rbibb View Post
...Of course there is no free lunch - you will burn more fuel as well...
Actually, the opposite is true. High compression does not increase the displacement of the engine, it simply allows the air that you do have to produce more work. That's why modern cars are going to increasingly higher compression... It increases the efficiency of the engine.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 08-20-2009, 05:37 PM
airguy's Avatar
airguy airguy is offline
Correct - the quantity of fuel burned is a function of the swept volume (displacement times RPM) and the mixture. It has nothing to do with compression ratios. Higher compression ratios in piston engines give a higher thermodynamic efficiency.
There is another thing to consider though - if you ever want to run mogas, those high compression pistons are going to cause you heartburn in the form of detonation. You are pretty locked in to 100LL if you run 9.5:1.
Old 08-20-2009, 05:38 PM
frankh's Avatar
frankh frankh is offline
Default Depends on fuel too
Engine suppliers recommend 8.5:1 max for autofuel. But I bet 9.2:1 would be ok as well..not that I intend to experiment.
Frank
Old 08-20-2009, 05:57 PM
asav8tor asav8tor is offline
I thought about this also and even considered 7:1 to burn regular gas. Then I though a max mpg combo (though reducing total performance) might be a high compression build but limit the MP. The enriching at full power argument is probably NA if you take off at significantly reduced power. I have taken off at 20". This would be a compromise build to get max miles at min $.
Old 08-20-2009, 06:58 PM
Ted Johns Ted Johns is offline
Default Details
Not exactly. The details matter. Increasing the compression raises both thermal and volumetric efficiency.
Increasing thermal efficiency improves the BSFC of the engine.
Increasing volumetric efficiency improves the ability of the engine to fill the combustion chamber with fuel - air mixture.
Both are responsible for the increase in HP due to an increase in CR.
The increase in VE allows an engine to burn more fuel.
Most hot rod mods to an engine focus on improving VE (porting, bigger valves, camshafts...). Increasing CR is one of the few that improves both VE and TE.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
Old 08-20-2009, 07:27 PM
Toobuilder's Avatar
Originally Posted by Ted Johns View Post
Not exactly. The details matter. Increasing the compression raises both thermal and volumetric efficiency...
Ummmm...
VE is an expression of the ability to fill a cylinder during a combustion event. In reality, one cylinder of a Lyc 360 is 90 cubic inches, but it is a truly rare event to have a naturally aspirated engine gain 100% VE. VE is simply tied to the ability to fill and expel the cylinder volume each combustion cycle, which is tied directly to valve timing, port configuration and induction/exhaust design (and some "shrouding" of the valve by the cylinder wall and piston). How does "smashing" a fixed volume of air more (i.e. high compression) improve the ability of the engine to ingest or expel the air?
I'll give you that the exhaust tuning will be altered because of the higher compression, but with an aircraft engine, the exhaust is rarely even close to tuned to begin with.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 08-20-2009, 07:47 PM
It's not a large effect, but increasing the CR increases the intake signal, for several reasons.
Stronger vacuum signal, due to the smaller amount of residual gas in the combustion chamber.
Stronger vacuum signal in the valve overlap region due to the increase in exhaust port velocity, due to the higher BMEP. This effect is improved with tuned exhaust, but does not depend exclusively upon it.
Both the VE and the TE improvements are small for the CR changes being discussed here.
Dog is my co-pilot.
Ted Johns
RV9 emp & wings
